SS Works 11.8" 4-pot brake kit...whaddaya think?
Old Mar 12, 2002 | 06:13 PM
GQ 05YellowEVO8's Avatar
Default SS Works 11.8" 4-pot brake kit...whaddaya think?
http://www.racingcraft.com/SSworks-brake.shtml
Lemme know
Old Mar 13, 2002 | 03:50 AM
JohnnyBoy's Avatar
Default Re: SS Works 11.8" 4-pot brake kit...whaddaya think? (VTEC-MAN95GSR)
Those are sweet! not a bad price either....
Old Mar 13, 2002 | 05:12 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
well, if you give me a few months, i will meet you at an event and show you first hand. yasu is installing them on his race spec eg, and i might be able to con..er..convince him to let me race it. seriously, it looks to be a good kit.
Old Mar 14, 2002 | 02:54 AM
Kengs's Avatar
Default Re: SS Works 11.8" 4-pot brake kit...whaddaya think? (rodney)
Dee (drealgsr) has them on his GS-R in Okinawa; check his post in Forced Induction a while back
Old Mar 14, 2002 | 03:31 AM
Dee's Avatar
Dee
Default Re: SS Works 11.8" 4-pot brake kit...whaddaya think? (kengs)
Eventhough blue is SS Works' team color they should have painted the calipers black or silver because this is one nasty color. The calipers are overhauled 4 pot Skyline GTS-T type M units with the OEM mount tabs shaved so an adapter can be used to mount the calipers to many different vehicles. The Rotors are 300mm Mugen pieces. Atleast 345mm of ID is needed on a 15" wheel to use this kit. I also had to shave the raised area where NISSAN once resided and buy a 10mm spacer & 10mm longer wheel studs in order to get this setup to fit during my test fitting. The kit does NOT come with brake pads but I think 300ZX TT calipers are the same size.
If I find a way to get S2000 at a good price I might try to reproduce this kit since GTS-T's are plentiful in boneyards.
Rotor is mounted wrong because this was only a test fitting!
BWRSUPPORT
Aug 28, 2013 01:38 PM
eg2wes
Sep 29, 2009 03:07 PM
letsstophere
Dec 16, 2005 06:46 AM
Got Milk
Aug 28, 2004 11:09 AM
