Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
Idle surging problems and backup mode
Old Nov 23, 2005 | 07:21 PM
freddy_hung's Avatar
Default Idle surging problems and backup mode
Acura Vigor: when the car stars, it warms normally, when the idle settles in 1k rpm more or less.. the engine starts to rev up and down from 800 rpms to 1200 rpms.... then in aminute or less the idle settles again and then the ecu goes into backup mode...... i have tested with 3 ecus and the behavior is the same... the car starts, the idle settles, the idle goes crazy, the ecu tries to fix it, it fails to do so, and then go into backup mode.... what can be wrong??? please i need some help!!!!
Old Nov 23, 2005 | 09:13 PM
tnord's Avatar
Default Re: Idle surging problems and backup mode (freddy_hung)
sounds like the PCV valve problems i used to have with my nissan's.
Old Nov 25, 2005 | 03:07 PM
LOWCO R's Avatar
Any DTCs stored? Vacuum leaks at the intake manifold gskt? Fast idle valve stuck open is fairly common?
RinzEG6
Nov 24, 2014 12:02 PM
followthadollar
Apr 20, 2010 06:23 PM
typer_696
Aug 8, 2009 01:43 PM
djmatix
Aug 11, 2007 12:45 PM
