HOW TO: change the bushing on the shift linkage / stabilizer?
ha thats funny cause i just recently got the urge to do them to my car and i picked up some enerygy suspension bushings at pep boys the day before thanksgiving and just had to put them in so thanksgiving morning im freezing my *** of putting them in. the round on is a bitch especially if you keep the stabilizer bar connected at the shifter cause you have to put it on under the car. (i should of took the whole thing out). if you put the dished part in first it bends easier and then just squeeze it with plyers and it pops right in, just dont forget the wd-40. the other bushing is pretty easy, i bent the flare a little so it went on no problem.
http://www.irwin.com/irwin/con...false
I used a set of thoses, Lined up the bushing, put a bunch of grease on it, and jsut kept clamping down on. I have used these things a thousand time for bushings and other such stuff.
