Ls block with pr3 pistons/b16a head
Old Nov 23, 2005 | 05:34 PM
SiR Inspired ED7's Avatar
Default Ls block with pr3 pistons/b16a head
Hey guy's i currently have a stock b16a in my 88 Crx Si and i was looking into ls/vtec and i was wondering if the pr3 pistons would be good to be slapped on the ls block along with my b16 head. Anyone seen/heard good/bad stories? let me know what you think.
Old Nov 23, 2005 | 06:06 PM
civicjdmb16a's Avatar
Default Re: Ls block with pr3 pistons/b16a head (88 Crx Si)
your gonna raise the compression a bit. never heard anything bad about it. prob a good idea
Old Nov 23, 2005 | 06:24 PM
Default Re: Ls block with pr3 pistons/b16a head (civicjdmb16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicjdmb16a &raquo;</TD></TR><TR><TD CLASS="quote">your gonna raise the compression a bit. never heard anything bad about it. prob a good idea</TD></TR></TABLE>
yea i know i'll raise compression,but just wanting to know if it's been an unreliable setup, any more input would be appreciated.
Old Nov 24, 2005 | 10:05 AM
jdm91integ's Avatar
That's the exact setup I'm running. I say go for it. That bump in compression will give you some extra horsepower. Just make sure you run 91 octane and stock timing.
Old Nov 24, 2005 | 02:51 PM
Default Re: Ls block with pr3 pistons/b16a head (jdm91integ)
Do they just slip in or any needs machine work to get done? i know i'll need 91 oct even though i just run 91 on my b16
Old Nov 25, 2005 | 08:11 AM
they are both 81mm so its a drop in affair
Old Nov 25, 2005 | 02:46 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicjdmb16a &raquo;</TD></TR><TR><TD CLASS="quote">they are both 81mm so its a drop in affair </TD></TR></TABLE>
What rods will i have to use?
Old Nov 25, 2005 | 07:21 PM
you would use your stock rods
Old Nov 26, 2005 | 03:52 PM
Stock as in the b16 ones right?
Old Nov 26, 2005 | 09:31 PM
no you would use your b18 rods
Old Nov 27, 2005 | 01:15 AM
k thanks anyone have estimate Compression numbers i would have with the pr3 pistons on the ls along with the b16 head?
Old Dec 13, 2005 | 03:03 AM
urnotfast's Avatar
11.3 to 1
Old Dec 13, 2005 | 10:58 AM
integkc's Avatar
Default Re: Ls block with pr3 pistons/b16a head (urnotfast)
yea it's bout 11:3 to 11:4 to 1 the only thing i recommend getting new piston rings and get some new rod bearings then you'll be straight ur gonna love it, a great power increase....
Old Dec 22, 2020 | 06:21 PM
Johnny Vg's Avatar
what head gasket i need for this setup?
jdm 1080p
May 4, 2012 09:39 AM
VTEC2841
12
May 11, 2007 05:49 PM
92eg6lsvtec
Jul 22, 2005 12:11 PM
sPaRk'iT
Oct 18, 2004 01:36 PM
jdmefhondachassis
Aug 17, 2004 10:50 AM
