Installing foglights?
Old Nov 23, 2005 | 04:29 PM
5po0n_Dc2's Avatar
Default Installing foglights?
I was wondering if there is a write-up or DIY on installing JDM foglights on the JDM Sir front bumper? Does anybody know exactly what to do? Wiring? If so, post pics. Searched already and couldn't find anything. I am planning to buy some, but don't really know how to do it. Anything would help, thanks.
Square foglights:
Round foglights:
Old Nov 23, 2005 | 05:17 PM
5po0n_Dc2's Avatar
Default Re: Installing foglights? (5po0n_Dc2)
bump
Old Nov 23, 2005 | 05:33 PM
fourthgenhatchB17's Avatar
The square fogs in the picture have the brackets for mounting still attached. If u take off your front bumper and look and try to fit them, you should clearly see where and how they bolt up. Just go ahead and look for yourself....its very easy.
For the round fogs, those actually attach to the bumper support on the JDM front bumper. So basically, if u have the round fogs mounted properly, and u take off your JDM bumper, the fogs will come with it. Unlike the round ones, the square fogs will stay on the car when u remove the bumper.
Your bumper will also need to have the appropriate cut outs.
Old Nov 23, 2005 | 11:43 PM
5po0n_Dc2's Avatar
Default Re: Installing foglights? (fourthgenhatchB17)
I heard there are lines or certain cut outs on the back of the front bumper. Is that true? All u have to do is cut them out? Is it exact fit for the foglights?
Old Nov 24, 2005 | 12:56 AM
Wraith's Avatar
yes there are lines on the back of the bumper , to show where to cut out.
Old Nov 24, 2005 | 08:49 AM
PIMPALA-SS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">The square fogs in the picture have the brackets for mounting still attached. If u take off your front bumper and look and try to fit them, you should clearly see where and how they bolt up. Just go ahead and look for yourself....its very easy.
Your bumper will also need to have the appropriate cut outs. </TD></TR></TABLE>
i agree with this 100%
only thing is on the round lights, the fogs themselves dont actually mount the the bumper support, they have a bracket that runs the length of the bumper.. it mounts directly to the support, and the brackets on the fogs mount to that. if they arrive like they are pictured from PWJDM, the round ones wont have anything to mount to, and you will be screwed.
in my 90 Si, i also had to remove the lower airbox resonator (factory junk i wasnt using anyway) on the passenger side, and the washer bottle on the driver side. for some reason, the fogs werent even CLOSE to fitting with those two things in the way.
Old Nov 24, 2005 | 12:16 PM
Default Re: Installing foglights? (PIMPALA-SS)
Ok ok so the round fog mounting configuration is incorporated into the bumper support, same difference right, lol. Also, with the round ones, you will need to get the rubber shroud/seal or else it just looks stupid. Password should be able to get u those too.
Old Nov 24, 2005 | 02:08 PM
DUFFM4N's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">Ok ok so the round fog mounting configuration is incorporated into the bumper support, same difference right, lol. Also, with the round ones, you will need to get the rubber shroud/seal or else it just looks stupid. Password should be able to get u those too.</TD></TR></TABLE>
they sell the rubber shroud separate? cuz thats wut im missing from my round fogs
thats why mine are mounted directly behind the SiR bumper grill, and i need to take them outta there soon to make room for something else
Old Nov 24, 2005 | 02:18 PM
jspeczcturbo's Avatar
here's a thread i did with the instructions to install 4g oem fogs on my car.
http://www.clubcivic.com/board...58294
Old Nov 24, 2005 | 02:50 PM
Default Re: Installing foglights? (DUFFM4N)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DUFFM4N &raquo;</TD></TR><TR><TD CLASS="quote">
they sell the rubber shroud separate? </TD></TR></TABLE>
Hit them up and see. I know at one time they had them new in the bag.
Old Nov 24, 2005 | 02:52 PM
DUFFM4N's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">Hit them up and see. I know at one time they had them new in the bag. </TD></TR></TABLE>
thanx eric
Old Nov 24, 2005 | 03:11 PM
drSquish's Avatar
those 4th gen lights are so badass with those covers. If i could somehow find them...
Old Nov 24, 2005 | 05:58 PM
PIMPALA-SS's Avatar
BTW, did u check PWJDM? they dont have either foglight, and dont plan on getting them any time soon (what they told me when i called about a month ago)
im actually trying to sell my complete set of round fogs for $225 plus shipping. comes with bracket, bumper cups, all nuts and bolts, AND the OEM switch.
Old Nov 24, 2005 | 09:14 PM
5po0n_Dc2's Avatar
Default Re: (PIMPALA-SS)
Thanks for all the help and advice, appreciate it. Does anybody have pics of how to wire up the foglights? And so PWJDM didn't have the rubber seals/covers in?
Old Nov 25, 2005 | 07:11 AM
PIMPALA-SS's Avatar
dunno if they had the cups in stock, but they dont have either foglight.
Old Nov 25, 2005 | 04:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PIMPALA-SS &raquo;</TD></TR><TR><TD CLASS="quote">dunno if they had the cups in stock</TD></TR></TABLE>
Probably a special order item.
Old Nov 25, 2005 | 06:43 PM
5po0n_Dc2's Avatar
Default Re: (5po0n_Dc2)
I seen a post of replica JDM foglights, does anybody know where u can buy those from? Something like the clear APC foglights? Kragens? Auto-Zone? And does anybody know if the old stock prelude foglights will fit on a EF9?
Old Nov 25, 2005 | 06:56 PM
Stunna MIKE's Avatar
Prelude fog's fit perfactly on an EF.. so you can also just get the OEM usdm fogs for your EF aswell from the dealership.
Old Nov 25, 2005 | 07:02 PM
5po0n_Dc2's Avatar
Default Re: (Aaron EF9)
Really? Do u know how much they are from the dealer? Is complete with the switch and wires?
Old Nov 25, 2005 | 07:05 PM
You would have to tell them. Umm mabey $100-$200.
Let me check. Give me a few.
Old Nov 25, 2005 | 07:09 PM
I dont know if this is the Foglight or not. But the price isnt list'd, Hold on im still checking
Old Nov 25, 2005 | 07:12 PM
Oh ****, 150 Each. So $300 With no wiring
Old Nov 25, 2005 | 07:14 PM
Oh ****, let me retract my last statement. For everything its $200+ Each. And just for the foglight its like $150
Old Nov 25, 2005 | 07:18 PM
5po0n_Dc2's Avatar
Default Re: Installing foglights? (Aaron EF9)
Damn! Thats pretty expensive for foglights. I might as well order them for passwordjdm for $270 with everything. huh? what do u guys think?
And here are stock OEM Civic Ones.
08V31-SH0-100 035 FOGLIGHTS - 1 $169.00
08V31-SH0-1M001 035A FOGLIGHT ASSY., R. - 1 $77.10
Theres part number and price for the EF ones. Thats each.
Hmm.. I dont know, I don't get it.
Heres the link.
https://www.hondapartsdeals.co...XEX01
