power steering & a/c?
Old Nov 23, 2005 | 04:04 PM
Slowass4dr's Avatar
Default power steering & a/c?
Iv decided that i want to put a b18 in my civic lx. i wanted to know if it was possible to keep the power steering and a/c i dont want my girl bitching in the summer if it is possible can someone give me info on it. thnx
Old Nov 23, 2005 | 06:51 PM
bagpipe goatee's Avatar
yeah, you can. the ac compressor might be different, so you might have to buy hasport's b to d series ac compressor bracket. good luck.
Old Nov 24, 2005 | 02:13 PM
Slowass4dr's Avatar
Default Re: (bagpipe goatee)
can anyone else clarify on this and if its right what website can i go to buy the parts i need
Old Nov 26, 2005 | 09:13 AM
the b18 when you get it should have a power steering pump on it already. attach it to your power steering lines (if i'm wrong, someone correct me)
i would say the same about the a/c, but if i remember right, the lines are different. thus hasport (you can go to one of their dealer's websites or maybe you can buy it from their website or something) has a bracket that will bolt to a b series block and let you bolt your d series a/c compressor to.
Old Dec 2, 2005 | 04:02 PM
Slowass4dr's Avatar
so i can use the powersteering pump thats on the b18 and the line from the lx but no the a/c correct?
Old Dec 2, 2005 | 07:13 PM
Slowass4dr's Avatar
Default Re: (Slowass4dr)
anyone
Old Dec 11, 2005 | 06:54 PM
Slowass4dr's Avatar
bump
Old Dec 11, 2005 | 07:06 PM
Mach69's Avatar
That sounds about right. Use the b18 powersteering pump. Just hook up the LX lines to it.
As far as a/c. go to http://www.hasport.com
Find the d to b a/c compressor bracket. I think its like 100 bux. When you are swapping the engine. Just unbolt the a/c compressor from the d-series block and from the compressor bracket. DO NOT UNHOOK THE A/C LINES! Then put the b-series engine in. Then bolt the d to b (b to d?) a/c compressor bracket to the b18 block, then the d series a/c compressor to the bracket, and ur done with a/c.
415cpa
Northern California (Sales)
Dec 1, 2010 06:17 PM
pubestripe
Jan 23, 2005 03:33 PM
blundar
Nov 7, 2002 07:19 AM
