Apexi VAFC II problem
I've got it all wired and spliced. Grounds are in the right place. I've checked it over a ton of times. I can't get power to the VAFC. Anyone know of what I should check?
Make sure you have teh ahrness plugged in . I know it sounds stupid but when I first put my VAFC in I forgot to plug the harness in from the ecu to the VAFC. Make sure you have Both power wires spliced into the right wire in the ecu.
Matt
Matt
