F22A1 swap for H22 need help
Old Nov 23, 2005 | 10:02 AM
rumdig2001's Avatar
Default F22A1 swap for H22 need help
Sorry people but I searched and could not find **** about swaping a H22. If someone knows more about this. I have a 93 lude s-type w/blown F22A1 swaping it for an H22 but need to know what all is needed to perform this without the headaches. Any info is appreciated as I am running out of Hydrocodones.
Old Nov 23, 2005 | 10:06 AM
AnthonyG2003
Guest
Posts: n/a
Default Re: F22A1 swap for H22 need help (rumdig2001)
If I were you I'd take care of the drug problems before worrying about the engine...
Old Nov 23, 2005 | 10:34 AM
SteveoBA8's Avatar
Default Re: F22A1 swap for H22 need help (AnthonyG2003)
lay off the dope man. Then you can touch your car.
simple run down
f22 engine harness can be used but lengthening some wires is neccesary
wire vtec( Check prelude Faq's)
Wire knock sensor
use usdm f22 fuel rail,use h22's injectors and fuel pressure regulator
BUY A MANUAL. $20 chiltons from oriellys will do the trick
bizzle2288
Aug 1, 2012 12:07 AM
newtype_racing
Nov 14, 2008 12:29 PM
otsegolectric
Dec 3, 2007 07:22 PM
EuRoBrO
Jul 20, 2004 09:54 AM
gtfourmn
Nov 11, 2002 09:39 PM
