Flywheel\Pressure plate bolts
Old Nov 23, 2005 | 09:09 AM
Voodooboy520's Avatar
Default Flywheel\Pressure plate bolts
It says to replace these, and mine do have some rust on the heads. Should I replace them? I want to to be safe, but
1. Thier like 3 bucks each, and
2. I have to order them, meaning a delay
Thanks
Old Nov 23, 2005 | 10:06 AM
Kwicko's Avatar
Default Re: Flywheel\Pressure plate bolts (Voodooboy520)
First time I replaced a clutch ('90 Integra), I replaced the flywheel and pressure plate bolts, 'cuz I wanted to "do it right". That was also the LAST time I replaced those when I did a clutch. Nowadays I re-use them unless they're really chewed up and I just can't get a socket on them. I used my old ones when I put the new clutch in my '91 CRX over two years ago, and haven't had any problems with the clutch, flywheel, transmission, or anything else...
Mike
Old Nov 23, 2005 | 10:18 AM
crexer's Avatar
Default Re: Flywheel\Pressure plate bolts (Kwicko)
ive never heard of seen anyone order new clutch bolts....mine and everyone i know seems to have no issues with re using them. If it were the head bolts I would say yes.
Old Nov 23, 2005 | 04:06 PM
hotboxedcrx's Avatar
I've always reused mine, That is what i would suggest.
Old Nov 23, 2005 | 07:42 PM
SuperSteve737's Avatar
Never had any problems re-using the clutch and pp bolts.
Old Nov 24, 2005 | 06:57 AM
HondaFerris's Avatar
Default Re: (SuperSteve737)
yes you can reuse the bolts as long as the heads on the bolts arent all stripped or anything happy turkey day!
p.s. forgot to mention, you should use blue loctite on all the bolts and make sure you torque all the bolts to the proper specs
Old Nov 24, 2005 | 07:06 AM
steelbuster's Avatar
Default Re: (HondaFerris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaFerris &raquo;</TD></TR><TR><TD CLASS="quote">p.s. forgot to mention, you should use blue loctite on all the bolts and make sure you torque all the bolts to the proper specs </TD></TR></TABLE>
What he said.
I don't know what your replacing but if your installing a new clutch you should resurface the flywheel. Many times you will wind up with clutch chatter if you don't.
Enjoy the Turkey
Old Nov 24, 2005 | 07:09 AM
CRXBart's Avatar
Default Re: Flywheel\Pressure plate bolts (hotboxedcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotboxedcrx &raquo;</TD></TR><TR><TD CLASS="quote">I've always reused mine, That is what i would suggest. </TD></TR></TABLE>
Me too reused probally 20 different times, on different motors and setups I've worked on. No problems as of yet.
lsvtec101
Transmission & Drivetrain
Mar 6, 2009 09:23 PM
fwdlooser93eg
Jul 24, 2006 06:52 PM
jdmintegra1994
Nov 21, 2003 10:15 AM
reefer_bob
Aug 13, 2002 05:43 PM
4doorH22
Mar 12, 2002 06:31 PM
