Black Side Trim strip removal ???
Old Mar 12, 2002 | 04:53 PM
carsaregood's Avatar
Default Black Side Trim strip removal ???
quick question:
those black strips that go lengthwise across my hatch that go from the front wheel well to the rear wheel well (trim strips.. i guess is kinda a more proper name).... how are you supposed to remove them? I want to take them off to paint them flat black because they've faded. thanks alot!
Old Mar 12, 2002 | 05:13 PM
Louie B.'s Avatar
Default Re: Black Side Trim strip removal ??? (carsaregood)
I would recomend leaving them on the car and masking off the rest of the car. I don't think you can get them off without destroying them.
Old Mar 12, 2002 | 05:15 PM
markedOO1's Avatar
Default Re: Black Side Trim strip removal ??? (thumpu77)
I'd recommend polishing them to restore the black....they'll come back...
to remove them w/o destroying the clips (which are like $3.50 each from Honda)...you'd ahve to take off the interior panels...
Old Mar 12, 2002 | 05:38 PM
Default Re: Black Side Trim strip removal ??? (marked001)
ew, i don't want to do that. what do you recommend polishing them with?
Old Mar 12, 2002 | 06:49 PM
kyler's Avatar
they're just rubber coated so if you buff them with very light sandpaper (like 1000 grit) you will take off the damaged upper layer...
then use back to black or carnuba wax to make it last.... paint doesnt stick well....
Rand The Man
Sep 2, 2010 09:39 AM
RED DA
Jan 24, 2007 11:47 AM
litterbox
33
May 9, 2004 11:55 AM
jasonb
Sep 11, 2002 09:37 AM
allmotorEG-SI
Jun 2, 2002 12:17 PM
