problem.
umm, when i am drivin and go over bumps and hills i hear a squeakin noise comin from the front of my car. like i believe its over where the right front wheel is. i think it might be a shock or somthin. it only happens wen i go over bumps though. any help or suggestions to what this is , and how to take care of it?
-thank you.
-thank you.
What yr is it? It could be a host of things, but if its old enough the CV joints on the car are too old and dont protect your driveshafts anymore, so that might be something to look at. Your shocks/struts could also be worn or arent lubricated anymore, and in either the shock/strut or CV joint case the metal on metal contact is causing the squeak. It could also be one of the motor mounts, but in any case take a look under your car and see if anything is excessively rusty, worn, or if its rubber then torn or cracked. Good luck, most times these things are cheap and easy fixes.
es01civy
21
Nov 10, 2013 06:50 PM
forever slow EG6
Feb 26, 2003 02:10 PM
