What axel fits my 92 civic with b16a?
I need to replace my axel in my 92 civic. It was originally an si and now it has a b16 in it. What kind of axel will fit it? Any axel from a d series fit?? Thanks
Mike
Mike
No you have a B-series motor so you can't use D-series axles!
I've read that any 94-01 Integra axle should work, but like I said I used Del Sol DOHC VTEC axles since the Del Sol <U>DOHC VTEC </U>is a B-series DOHC VTEC motor
anything off a d series motor will fit to a d series, and any b series motor will fit to a b series motor............so to ur question no not any d series axels will fit to a b series motor....jsut buy some integra axels or 99-00 civic si axels
what intermediate shaft do you have? according to hasports website :
90-93 Integra axles, 94 up Integra axles, 94-97 Del Sol VTEC axles or 99-00 Civic Si axles.
Note: The intermediate shaft seal in the left side of the transmission is different for 90-93 Integra axles. Depending on axle transmission combo, it may have to be changed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typeoneeg6 »</TD></TR><TR><TD CLASS="quote">what intermediate shaft do you have? according to hasports website :
im suprised it took someone that long to ask about the int. shaft... a shaft from a 90-93 teg is female on the int. shaft and 94-01 teg, 94-97 del sol vtec, and 99-00 si are male on the int. shaft... this applies to the driver side only... all b series passenger side axles are the same... so find out which int. shaft you have then use what i just told you to determine which one you need
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeunreal »</TD></TR><TR><TD CLASS="quote">how the hell do i know if its male or female??
Mike</TD></TR></TABLE>
OMG
OMG
use GSR axels.. autozone w/ a lifetime warranty
and you will know which side goes in which.. the longer one goes into the transmission, the shorter one goes into the the other side.
Happyfeat2006
15
Jun 15, 2023 04:58 PM
DC2_Jspec
Jul 19, 2002 05:51 AM
