CEL Cylinder Misfire
Old Nov 23, 2005 | 03:14 AM
Integra Integra's Avatar
Default CEL Cylinder Misfire
I was wondering if you guys could help me out a little bit, I am experiencing Cylinders 1-3 misfiring according to Auto Zone. What usually causes this to happen? I remember searching and people said to do a tune up and I ordered some things from Import RP here on the Honda-Tech Marketplace and recieved Iridium plugs, wires, cap + rotor and fuel filter? Do you thinks its the issue or something else like timing or something?
Thanks
Old Nov 23, 2005 | 03:23 AM
Default Re: CEL Cylinder Misfire (Integra Integra)
Also it usually goes on when I start the car and sometimes goes off
Old Nov 23, 2005 | 04:23 AM
97tegGS's Avatar
Did you have them read the codes?
I would do your tune up and double check your timing.
Your distributor/or other ignition componets could be on the fritz/on the way out.
Old Nov 23, 2005 | 09:11 AM
Default Re: (97tegGS)
Yeah I am planning on doing the tune up, valve adjustment, check timing and change my tranny fluid so hopefully it goes away.
Thanks!
Old Nov 23, 2005 | 10:51 AM
Default Re: (Integra Integra)
Another thing I noticed is when I first start it the RPM is really low then picks up and drops finally stays smooth....
Old Nov 23, 2005 | 11:32 AM
LoseRPunKx182's Avatar
one of the common things we see is that the plug wires are loose. autozone should have a little troubleshooting book...
gohonda
May 12, 2019 05:44 PM
90Rexx
Jul 3, 2009 06:23 AM
zeroairskter
Jun 13, 2009 10:03 PM
Lude-Lee
Mar 20, 2008 06:57 PM
AllMotor12s
Nov 11, 2007 04:20 PM
