Crank pulley sensor question
Old Nov 22, 2005 | 11:39 PM
jdmcivic1999's Avatar
Default Crank pulley sensor question
ive done the search but nothing really answered my question. ok so i just swapped a jdm b16 into my 99 coupe (OBD2B). the b16 is i believe OBD0 because there is no crank pulley sensor. now do i need to swap a oil pump that has the CPS sensor on it, or can i run the motor without a CPS. i know ill throw a check if i dont wire it up, but will it screw up the motor itself? i will be running a Type R ecu.
Old Nov 23, 2005 | 06:49 AM
Default Re: Crank pulley sensor question (jdmcivic1999)
anyone???
Old Nov 23, 2005 | 07:16 AM
SlowReaction's Avatar
I'm not sure if it'll mess with your motor but if I were you i'd put it on since your running a itr ecu. If not just run a jumper/p28.
Old Nov 23, 2005 | 01:35 PM
Default Re: Crank pulley sensor question (SlowReaction)
thanks, anyone else know if this is good or bad???
AzNsTyLe361
Aug 25, 2007 06:31 AM
jdmcivic1999
Nov 23, 2005 01:43 PM
pinota
Jan 8, 2003 11:18 AM
