losing oil, but can't find source
Old Nov 22, 2005 | 11:04 PM
beanbag's Avatar
Default losing oil, but can't find source
Hello,
Ever since my last oil change, I have been losing oil like 1 qt every 1.5-2k miles. Before, it was always .5 qt or less every 5k miles. The only thing that I did recently was run the seafoam treatment. Anyway, I looked for the tell-tale signs of oil consumption, but couldn't find anything:
exhaust soot is dry
no smoking out the exhaust
spark plugs look ok (tan color)
no coolant in oil
no oil in coolant (I saw some brownish deposits, but otherwise the coolant looked green and not yellow)
no leaks seen near valve cover, distributor, etc
no leaks seen under car, filter seems dry
So what could it be?
97 gsr, 68k miles
Old Nov 23, 2005 | 05:16 PM
beanbag's Avatar
Default Re: losing oil, but can't find source (vtecriver)
compression test with 6 cranks shows:
200 200 200 215 where the high cylinder is next to the distributor
Old Nov 23, 2005 | 05:42 PM
lVlemphizStylez's Avatar
Default Re: losing oil, but can't find source (beanbag)
my suggestion is double check for leaks because is Compression is fine...then its not burning it dude...especially since you see no smoke anywhere did all the other checks
Old Nov 23, 2005 | 06:04 PM
beanbag's Avatar
Default Re: losing oil, but can't find source (lVlemphizStylez)
I read somewhere that the upper ring can be ok and thus compression checks out fine, but a lower ring can be bust and cause oil consumption. But I'll get the car up on jackstands and check for leaks again.
Old Nov 23, 2005 | 08:16 PM
Dartanian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beanbag &raquo;</TD></TR><TR><TD CLASS="quote">I read somewhere that the upper ring can be ok and thus compression checks out fine, but a lower ring can be bust and cause oil consumption. But I'll get the car up on jackstands and check for leaks again.</TD></TR></TABLE>
Yeah, but you would see the tell-tale signs of oil burning. The first big sign is any sort of blackish buildup on the back bumper.
Get on the highway and step on it. Look in the rear view mirror for any smoke. If you see any, there is your problem: Bad rings.
Old Nov 23, 2005 | 09:58 PM
SIK IN DA HED's Avatar
New User
thats strange... if it aint leakin, your compression is good, and there are no signs of black exhaust on your rear bumper then maybe it could blowby youre gettin... but it would consume that much oil.
jonyi27
Apr 21, 2014 11:55 AM
blackeg
Jun 26, 2011 08:53 AM
Ohbebe75
Aug 4, 2010 06:29 AM
ealex
Mar 2, 2005 09:53 AM
quiksheit
Jul 9, 2004 02:16 PM
