Questions about engine bay painting and prep.
Old Nov 22, 2005 | 07:46 PM
guymosiris's Avatar
Default Questions about engine bay painting and prep.
I'm trying to get my engine bay re-painted black in my Integra while the motor's out. How did you guys take your passenger side harness out from the firewall. Did you take the dash off, heater core out? Or can you just weasel them out. How many coats of paint did you guys use? Was it a DIY or is it worth towing and paying big bucks. I'm still trying to get ideas. Also, if you re-located your fusebox, where under the dash did you mount it. Pictures will be gladly appreciated. 20 questions
Old Nov 27, 2005 | 12:57 PM
guymosiris's Avatar
Default Re: Questions about engine bay painting and prep. (guymosiris)
Bump
Old Nov 27, 2005 | 01:25 PM
kidkombo's Avatar
pay big bucks...or jsut strip your engine bay in your garage and shoot it yourself but ill tell you now, there are a BUTTLOAD of little clips, bolts and caps that you need to remove in order to have a truly painted engine bay.
Old Nov 27, 2005 | 07:56 PM
guymosiris's Avatar
Default Re: Questions about engine bay painting and prep. (kidkombo)
Yeah, I've got almost everything out. The abs unit/lines, master cylinder/lines, brake booster, and passenger side harness are still there.
hybrid2007
Welding / Fabrication
39
May 1, 2012 08:23 PM
chiboy002
Paint and Body
Dec 26, 2009 11:29 AM
welfarepc
Paint and Body
Oct 30, 2007 09:37 AM
91(si)hatchey
Oct 12, 2006 05:07 PM
fiebru1119
Jan 8, 2003 09:43 PM
