ps leak
Old Nov 22, 2005 | 06:54 PM
ap716's Avatar
Default ps leak
can someone help me im a noob. i know my power steering is leaking, but i dont know how to fix it. can someone tell me how to fix this? its for a 93 accord
Old Nov 22, 2005 | 07:03 PM
isquishplatano's Avatar
Default Re: ps leak (ap716)
Lucas Power Steering Stop Leak
u can buy it from any autoparts store.
but ofcourse.. it depends on where its leaking from...
i used stop leak. works great for me.
Old Nov 22, 2005 | 11:54 PM
CB7VTEC's Avatar
give us a general location where the leak is coming from...
Old Nov 23, 2005 | 07:12 AM
ap716's Avatar
i really cant tell but i can take pics of the leak if you want.
Old Nov 23, 2005 | 09:07 AM
iam7head's Avatar
Default Re: ps leak (isquishplatano)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by isquishplatano &raquo;</TD></TR><TR><TD CLASS="quote">Lucas Power Steering Stop Leak
i used stop leak. works great for me.</TD></TR></TABLE>
i would never use those, it leak because there's a problem, putting magic/snake oil into the system=
Old Nov 23, 2005 | 01:38 PM
CB7VTEC's Avatar
Default Re: (ap716)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ap716 &raquo;</TD></TR><TR><TD CLASS="quote">i really cant tell but i can take pics of the leak if you want.</TD></TR></TABLE>
Go ahead and post some pics.
The PS system on 4th gen is pretty simple as far as leaks. Check for foamed fluid at the PS reservoir and check the small rubber hoses. Also, look at the underside of your hood (directly above the pump) for PS fluid being flung up by the pump belt. If you see fluid at either place, then most likely its the PS pump seal that's failed and the pump is sucking in air.
If the problem isn't at the reservoir or pump, its most likely the feed hose that goes from the pump to the rack, or the rack itself.
Old Nov 23, 2005 | 02:25 PM
inomyhondas's Avatar
do not use stop leak,,,,,,,,,,,,most likely your p/s pump or p/s rack is leaking
Old Nov 24, 2005 | 08:08 AM
ap716's Avatar
Default Re: ps leak (inomyhondas)
can take better pics if needed. help me
Old Nov 25, 2005 | 07:59 AM
CB7VTEC's Avatar
Pump area looks ok. Take off that lower splash shield to get a better look at whats going on. There's a couple rubber PS hoses in that area. Maybe items 20 &17.
Also, your PS fluid in the reservoir looks reddish in the pic. You should make sure you have honda fuid in there.
94c1v1cex
Jul 30, 2007 04:22 AM
94c1v1cex
May 21, 2007 05:03 PM
nitroaccord105
Nov 9, 2006 09:21 AM
hungtat
Oct 19, 2006 12:33 PM
matt_in_sd
Mar 22, 2005 07:54 AM
