PCV Vavle for a 91 CRX
Old Nov 22, 2005 | 06:09 PM
CRX-Noob's Avatar
Default PCV Vavle for a 91 CRX
Hello everyone, i was just wondering where the pcv valve is located. Can anyone post a picture of it? I have the Chiltons repair manual but it doesnt really give me a good picture of were it is located.
Thanks.
Old Nov 22, 2005 | 06:15 PM
Tyson's Avatar
Default Re: PCV Vavle for a 91 CRX (CRX-Noob)
on the intake manifold, between the #1 and #2 cylinder runners. its a 90 degree bent plastic piece with a hose leading to the middle and thickest hose at the top of the intake manifold.
Old Nov 22, 2005 | 06:26 PM
CRX-Noob's Avatar
Default Re: PCV Valve for a 91 CRX (Tyson)
Im not sure if its the PCV, but i had a cracked hose right behind my motor. I pulled the hose off and there is a valve. I was told that the valve should just pull right out, this valve looked like it needs to be screwed out. The hose i removed from the vavle is also connected to the lower back of the engine. if this is not the PCV vavle then what the hell is it?
Thanks.
Old Nov 22, 2005 | 06:28 PM
Tyson's Avatar
Default Re: PCV Valve for a 91 CRX (CRX-Noob)
thats the PCV valve.
it will pop off. give it a good tug up.
or it will crack. hope that doesnt happen to you. it did for me. probably wasnt ever changed.
PCV valve is #7
Old Jan 2, 2006 | 09:36 AM
mrsuburban's Avatar
what is number 6 in that picture, the thing that the pcv valve connects to...??
Old Jan 2, 2006 | 11:29 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: PCV Valve for a 91 CRX (mrsuburban)
#6 is the oil breather chamber..
It redirects engine blow-by into the intake
while separating the engine oil from the vapors..
x91civichatch
Nov 14, 2005 03:21 PM
jvonb
Nov 12, 2005 05:26 PM
byronl
Mar 19, 2005 10:24 PM
CivicBoi
Nov 19, 2002 03:04 AM
