getting rid of wheel hop
Old Nov 22, 2005 | 05:09 PM
allmotor99lude's Avatar
Default getting rid of wheel hop
i have a 99 SH of which im about to put the motor back in. before i blew the motor (unrelated topic) every time i would launch above 2500 rpm's the wheels would hop like mad. what causes this and what can i do to get rid of it during launching? all input appreciated
Old Nov 22, 2005 | 07:27 PM
dblock2x's Avatar
what kind of tires/suspension do you have?
Old Nov 22, 2005 | 11:47 PM
DLudist's Avatar
decreasing your tire pressure might help a little. or let out the clutch a little slower
Old Nov 23, 2005 | 03:53 AM
MadCityLude
Guest
Posts: n/a
Default Re: (DLudist)
Motor mounts, bushings, and suspension. Also tires and wheel alighnment are the primary causes.
Search there is a topic from just a few weeks ago on this EXACT subject.
Old Nov 23, 2005 | 04:51 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: (KillaLude92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KillaLude92 &raquo;</TD></TR><TR><TD CLASS="quote">Motor mounts, bushings, and suspension. Also tires and wheel alighnment are the primary causes.
Try launching at 3K, find your sweet spot. Pratice is the key.
Hondas (FWD) are notorious for wheel hopping. You can't eliminate it, but you can reduce it.
Old Nov 23, 2005 | 07:28 AM
jakeiscool's Avatar
Banned
Default Re: getting rid of wheel hop (allmotor99lude)
so dont launch, if you have to, once you dump the clutch youve got to mash the gas pedal and go wide open right after you let the clutch go.
Old Nov 23, 2005 | 07:50 AM
The_Sober's Avatar
Default Re: (Sticky Tires)
practice...
Old Nov 23, 2005 | 09:16 AM
matix's Avatar
Default Re: (The_Sober)
When u put the new motor back in just put a front and rear motor mount insert from energy suspension in. This will eliminate alot of it.
Old Nov 23, 2005 | 04:37 PM
LeafBoy's Avatar
re-alignwheels and maybe balance them again or something
Old Nov 23, 2005 | 09:27 PM
BB4's Avatar
BB4
$32 es motor mount inserts
mrEM1
15
Apr 7, 2006 10:56 AM
b16a27
Mar 4, 2005 09:18 AM
lewdude
Feb 19, 2005 09:42 PM
brega3
Apr 22, 2003 08:07 PM
DLB1994
Jan 28, 2003 09:40 PM
