what can it do or will it show that when the dizzy go bad?
Old Nov 22, 2005 | 04:46 PM
4DRmafia's Avatar
Default what can it do or will it show that when the dizzy go bad?
what are the things to know that ur dizzy is junked ? bec i think my dizzy went out already
Old Nov 22, 2005 | 05:24 PM
SD_Lurker's Avatar
HT White Ops
Default Re: what can it do or will it show that when the dizzy go bad? (SkipMic2006)
Well one way is to take off your dizzy. When you have it off try and turn the key parts that locks into the cam. If that does not turn freely then your dizzy is bad. You can also pull one of your spark plugs and plug wires and leave it plugged in and have someone turn the key over to see if its getting spark. Try that with all four cylinders. Good Luck
Old Nov 22, 2005 | 05:26 PM
mr. carpenter's Avatar
Default Re: what can it do or will it show that when the dizzy go bad? (nicks_jdmstyle_ef9)
jumping tach, horrible fuel consumption, and running rich ie.. smell of gas.
Old Nov 22, 2005 | 05:27 PM
4DRmafia's Avatar
well i would do these things u just told me ...but i cant crank the car over now and no fire at all
Old Nov 22, 2005 | 05:28 PM
4DRmafia's Avatar
umm what u excalty mean by jumping tach ? like it'll stumble with a jumping tach? if so then that what mine is doing jumping between 0 to 1000 rpm
Old Nov 22, 2005 | 05:32 PM
Default Re: (SkipMic2006)
mine died on me at the track one day. i noticed as i got to the top of gear that the power would be lacking. it got worse through the course of the day and eventually left me on the side of the road. the tach was bouncing all over the place. my cat clogged up, backfired. the car only ran at high rpms.
Old Nov 22, 2005 | 06:25 PM
4DRmafia's Avatar
bec mines just now just sort of cut off on me but the car still moving and the rpm slowly moved down and i press the pedal all the way to the floor and it does nothing
Old Nov 22, 2005 | 07:38 PM
Redline130's Avatar
Check to make sure your rotor hasn't come loose. I had the exact same thing happen to me, and it was my rotor being loose.
Old Nov 23, 2005 | 05:09 AM
4DRmafia's Avatar
alright well here are all the things i replace at the same day when it started to stumble on me. new rotor ,dizzy cap, spark plugs and wires, new o2 , new fuel filter. it still stumblues until the car quited on me but i already have a new dizzy that i havent install it yet. but oil running down on the crank pully side? this is where it made me say wtf
Old Nov 23, 2005 | 06:09 AM
zccr-xsi's Avatar
Default Re: (Redline130)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 &raquo;</TD></TR><TR><TD CLASS="quote">Check to make sure your rotor hasn't come loose. I had the exact same thing happen to me, and it was my rotor being loose. </TD></TR></TABLE>
yes right! that **** has happen to me too.it took me 2 days off haedache and thinking.then on a last resort thing i decided to take off the dizzy to soder some wires to see if it would fix my prob.well when i opened the dizzy up i felt the rotor fall in my lap.i felt like a dumb *** cause thats why my car wouldnt start.,and it took me 2 dayz to figure it out.that happen twice btw.i took very lil bit of blue lock-tight and screwed it back in.hasnt came lose since.
Old Nov 23, 2005 | 10:46 AM
Markb16a's Avatar
if you see a code 4 or a code 8 then its def your dizzy man mine was shot and then I looked at the computer and oh what was it blinking a code 4 I asked my guy at the speed shop and see what he would say he told me if the compter is blinking a code 4 or a code 8 its a sensor in the dizzy and he said replace it. Just for future refrence. lata
Old Nov 23, 2005 | 11:04 AM
HiProfile's Avatar
Default Re: (Markb16a)
If the bushing inside goes bad, it starts grinding everything around it (orange dust, followed by magnetic particles). The sensors get chewed up, as do the rotor/cap contacts. The internals also heat up a lot, cooking the ingnitor & other sensors. The 'only runnin in high rpm' could be that it needed the extra amps from the alternator to help jump the enlarged rotor/cap gap.
Besides what also has been mentioned, it can also squeek if the bushing goes bad (as shaft bounces around).
sosasauce
Jul 12, 2010 06:10 PM
mardoiii
Nov 22, 2008 12:31 PM
Smash03
Jul 12, 2007 01:26 PM
91zSi
Jun 5, 2005 04:29 PM
patastinky
Jan 27, 2003 11:33 PM
