FS: d16y8 intake manifold - auto egr - jdm d15b obdii obd2 rare
this is a bit of a rare intake manifold...
came off the jdm obd2 d15b 3-stage vtec d15b
it has egr with a really nice removable mounting plate across the runners for possible intake additions or access for porting...etc...
it has the auto throttle body...
but
if you are friendly with machinist or are one yourself...
the iacv ports could easily be tapped to create a standard manual intake
you would just need a throttle body
other options i've heard of working are putting a resistor in the harness to fool the ecu into thinking there is an iacv present...
this manifold uses the 3-wire combo iacv/fitv on the tb
there are no provisions for iat on the manifold...you would have to use an obd2 intake pipe or drill a hole in an obd1 pipe and plop your iat on there with some silicone...etc...
comes with obd2 injectors
the tps connector is slightly cracked but doesn't prevent a good connection or effect the sensor itself
i can include the obd2 injectors if interested
the engine was tested before the tb was removed...
hooked up an iacv & iat and let them dangle...
no other codes were thrown from the intake manifold...
so everything is good on it
MAKE OFFER
but
MAKE OFFER
yo im intersested in da manifold......whats the lowest ull go shipped.....if i like the price ill buy on the spot....hold on to it fo me
tjdmcoupe
Jul 14, 2015 11:16 AM
CLICC916
Apr 5, 2005 03:59 PM
