High flow oil pumps
Old Nov 22, 2005 | 04:13 PM
dohdoh420's Avatar
Default High flow oil pumps
I was just wondering since I need to buy a new oil pump for my turbo d16y8 I am building if I should buy a high flow aftermarket one? are they worth the extra money? would I need one for boosting 17 to 25lbs.? also; how many psi does the stock oil pump make every 1000 rpm, I seen an aftermarket oil pump that increses 10psi for every 1000rpm, is this too much, or not needed for a street car? thanks
Old Nov 22, 2005 | 04:35 PM
bosco500's Avatar
Default Re: High flow oil pumps (dohdoh420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohdoh420 &raquo;</TD></TR><TR><TD CLASS="quote"> I seen an aftermarket oil pump that increses 10psi for every 1000rpm, is this too much, or not needed for a street car? thanks </TD></TR></TABLE>
You damn sure dont want a pump that pushes that much pressure. If I were you , I would stick with stock. You can adjust the pressure if its too low via a spring inside the pump.
Old Nov 23, 2005 | 02:44 AM
Adi Radoncic's Avatar
On Fire!
If anything buy a brand new oem honda pump.
Old Nov 26, 2005 | 09:02 PM
coneheadsracing's Avatar
Default Re: High flow oil pumps (Adi Radoncic)
why not go higher?? Just wondering what your reason is to this. My dad has a fully built motor for a trans-am, and it has a high volume and pushes well past 100 psi. With the pressure of your pistons from boost against your crank i'm not seeing why you wouldn't want high pressure. Anyways, i am interested in the pump if you have a link that would be great. I"m already boosted, but will be rebuilding my motor during the winter wonderland time.
Alexxxx
K Series
Apr 12, 2018 11:18 AM
Badassbigblock
Feb 17, 2018 01:19 PM
njmoro2
Honda Civic (2006 - 2015)
Nov 6, 2010 09:10 AM
Circuit Star-29
May 5, 2006 09:40 PM
Walterronny
Apr 10, 2006 05:34 AM
