Parts for the EG6
Old Nov 22, 2005 | 04:13 PM
DragonDRFTR's Avatar
Default Parts for the EG6
I'm doing a swap on my hatch I was wondering. Well most the parts on off a d15 work on the b16a also??? Stuff like the hoses, hydro lines for the trans, and harness.
Old Nov 22, 2005 | 04:35 PM
clint g's Avatar
Default Re: Parts for the EG6 (DragonDRFTR)
nope not compatible
Old Nov 22, 2005 | 06:08 PM
JunTec's Avatar
Default Re: Parts for the EG6 (clint g)
i could of told you that...
Old Nov 22, 2005 | 09:59 PM
Default Re: Parts for the EG6 (JunTec)
dammit, mayb the parts of a del sol would work better.
Old Nov 22, 2005 | 11:35 PM
civicEKzee's Avatar
YOu'll be able 2 use the hydro lines!!
but wire harness you might wana use an EX model
Old Nov 23, 2005 | 01:29 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Parts for the EG6 (civicEKzee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DragonDRFTR &raquo;</TD></TR><TR><TD CLASS="quote">dammit, mayb the parts of a del sol would work better.</TD></TR></TABLE>
Not unless it was a Del Sol that came with a B16 factory.
Your D series harness will work, you will have to add a few wires and lengthen the oxygen sensor i believe. But it will work. Any part that isn't physically attached to the motor/tranny in some way will work.
Old Nov 23, 2005 | 06:36 AM
Default Re: Parts for the EG6 (JDM_Ej)
yea I was planning on going to autozone and juss thinking about buying the parts for an b16 del sol. I was juss having trouble thinking about wat car to tell them I have so that they wouldn't expletive up on the parts. I actually intend on using the orginal harness that came with my d series motor, looking at everything know, it looks like it all clips in. Mayb I'll end up selling the b series harness that came with the front clip if I'm lucky.
Old Nov 23, 2005 | 06:38 AM
omega_s14's Avatar
anything off a d series motor will fit to a d series motor, and anything that is off a b series motor will fit to a b series.....
Old Nov 23, 2005 | 06:45 AM
1995Civic's Avatar
Default Re: Parts for the EG6 (omega_s14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by omega_s14 &raquo;</TD></TR><TR><TD CLASS="quote">anything off a d series motor will fit to a d series motor, and anything that is off a b series motor will fit to a b series.....</TD></TR></TABLE>
This is not true...
Old Nov 23, 2005 | 07:17 AM
Default Re: Parts for the EG6 (1995Civic)
yea, b/c the the some of the **** of a d15 will not fit on the d16, due purely to some of the size of the parts. I don't really know I about that much about b series, to my knowledge most of the parts r interchangable.
Old Nov 23, 2005 | 08:13 AM
B20VTECHUSTLER's Avatar
New User
he knew that
Old Nov 24, 2005 | 10:32 PM
Default Re: Parts for the EG6 (B20VTECHUSTLER)
well besides that is there anything else I should know for this swap????
Eraser X
Oct 15, 2012 07:59 AM
rkonfire
Jul 10, 2004 02:04 AM
