Motor oil leaking in my H22 distributor again
Old Nov 22, 2005 | 03:22 PM
morales232002's Avatar
Default Motor oil leaking in my H22 distributor again
Hi, a few month ago motor oil was leaking inside my H22 distributor. I took the advise, from someone in the website, to change the O-ring. A new O-ring was install, but a few month later I checked my distributor and there was motor oil inside the distributor again. Can anyone tell me what I did wrong the first time.
Old Nov 23, 2005 | 01:25 AM
gamblezhang
Guest
Posts: n/a
Default Re: Motor oil leaking in my H22 distributor again (morales232002)
inside or outside? there is a o ring inside the disritbtr. you need to take out everyting to find it out. (sorry for my english).
Old Nov 23, 2005 | 05:05 AM
junbb1's Avatar
Default Re: Motor oil leaking in my H22 distributor again (gamblezhang)
there is a seal on your dist shaft that leaks sometimes. Honda does not sell this seal. you must replace the dist sub assembly to repair. Although there is an A/M company that manufactures those seals but i do not know who. do some research and you should be able to find out.
Cameron k.
60
Sep 25, 2012 07:19 PM
gixxerboy750
Aug 7, 2010 11:37 AM
crxricer66
Jan 11, 2008 01:57 PM
s2kkid
Dec 12, 2005 06:42 AM
morales232002
Sep 5, 2005 10:16 AM
