STRANGE PROBLEM
Old Nov 22, 2005 | 02:28 PM
efyou's Avatar
Default STRANGE PROBLEM
alright i have a strange problem here, i jus fixed my fuel pump and put a new main relay in my car...everythings running fine...then im driving home from school at night and when i hit the brakes and come anywhere close to about <20 mph, my voltmeter reads about 10.5 volts and the car struggles to stay started...sometimes dies right there... the only time it doesnt is if i dont have any draws on and im stopped by holding my ebrake...what could be the problem?
Old Nov 22, 2005 | 02:36 PM
west nile's Avatar
maybe alternator or battery?
Old Nov 22, 2005 | 04:31 PM
teler86's Avatar
Default Re: (west nile)
my car did the same thing before, it was the alternator
Old Nov 22, 2005 | 05:36 PM
efyou's Avatar
Default Re: (teler86)
well i jus replaced the alternator... its from honda...no autozone cheapo...the belts bad...which i did by a new one but havent replaced it yet...it got dark on me and cold. think that could be a problem
Old Nov 22, 2005 | 07:27 PM
Crimson_Tide's Avatar
Default Re: (efyou)
id check all your battery connections and make sure theyre clean... most EF's have this problem except it is not very bad... just the headlights will dim if brakes are used... another thing you could try to do is eliminate any extra draws on the alternator(amps, neons, fog/driving lights, etc)... ive also heard about replacing your brake light bulbs with some led ones that are made by some company(cant remember the name right now)... they dont put as much of a load on the alt... good luck man
-Josh
Old Nov 22, 2005 | 08:10 PM
bagpipe goatee's Avatar
Default Re: (efyou)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efyou &raquo;</TD></TR><TR><TD CLASS="quote">well i jus replaced the alternator... its from honda...no autozone cheapo...the belts bad...which i did by a new one but havent replaced it yet...it got dark on me and cold. think that could be a problem</TD></TR></TABLE>
the belt's not a problem as long as it's not squealing. that is, until it breaks on you.
if it's on there and not squealing, your problem's something else.
Old Nov 23, 2005 | 02:37 AM
teler86's Avatar
Default Re: (bagpipe goatee)
how many ribs are on your belt? if it only has 3 such as the stock civic motors it would cause it to slip. if you have a b-series you need a 4 ribbed belt.
btw i see your local how far away is fairfield from cleveland?
Old Nov 23, 2005 | 10:42 PM
efyou's Avatar
Default Re: (Crimson_Tide)
lemme know that company name if u ever remember...i dont have any extra draws on my car...cd player...thas it...evertyhing else is factory...ive noticed that the brakes lights always have more draw on them than they should...so maybe thas my problem
Mishka24
Honda Fit
Jun 24, 2010 11:15 AM
MadTown
May 14, 2010 02:25 PM
efjones9
Mar 19, 2010 06:37 PM
97elitehonda
Jan 3, 2008 07:54 PM
Htownmalu
Nov 5, 2004 12:17 PM
