Cable>>Hydro tranny conversion...
Old Nov 22, 2005 | 01:34 PM
NINE9DC4's Avatar
Default Cable>>Hydro tranny conversion...
What exactly do I need for the conversion besides the Hasport kit? I have a 1990 Si hatch and plan to do a B20/V-TEC swap into it with an S80 LSD tranny. Any help such as a list would be greatly appreciated.
Thanks.
Old Nov 22, 2005 | 01:42 PM
CRXb18Turbo's Avatar
Default Re: Cable>>Hydro tranny conversion... (NINE9DC4)
easier with the hasport kit.
unless you have all the component for hydro system.
Old Nov 22, 2005 | 01:53 PM
NINE9DC4's Avatar
Yeah I planned on getting the Hasport kit. I meant as in lines and slave cylinders and whatnot...
Old Nov 22, 2005 | 01:55 PM
Default Re: (NINE9DC4)
If you going to buy the kit... all you need is nothing.
but probably the 90-93 da cable.
Old Nov 22, 2005 | 03:23 PM
NINE9DC4's Avatar
By the Hasport kit, I mean the one with the engine mounts and the conversion brackets. There is no other stuff I need like the slave cylinders or anything?
Old Nov 22, 2005 | 03:40 PM
EP3_05's Avatar
No you just need the EFB2 mount kit from HASport. The kit eliminates the need for any of the hydraulic system from the donor car.
Old Nov 22, 2005 | 03:57 PM
NINE9DC4's Avatar
Good lookin' brah. Thanks for the info.
Old Nov 22, 2005 | 05:13 PM
88 rex's Avatar
EFB2 kit and a DA clutch cable is recommended.
Good luck!
Old Nov 22, 2005 | 08:11 PM
jdmcars.com's Avatar
The EFB2 is the answer, along with the needed shift linkage as it sounds like you are still running the stock set up and don't have one.
You would also need the rear transmission mount bracket, unless the engine you have came with it, or are planning on buying has it.
Old Nov 23, 2005 | 05:47 AM
88 rex's Avatar
Default Re: Cable>>Hydro tranny conversion... (jdmcars.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcars.com &raquo;</TD></TR><TR><TD CLASS="quote">The EFB2 is the answer, along with the needed shift linkage as it sounds like you are still running the stock set up and don't have one.
You would also need the rear transmission mount bracket, unless the engine you have came with it, or are planning on buying has it.</TD></TR></TABLE>
Yea, forgot about the DA rear tranny bracket (and then you have to drill the holes out a little bit. Also, you will need a DA driver side motor bracket (the one that bolts the block to the mount).
Old Nov 23, 2005 | 02:42 PM
NINE9DC4's Avatar
I was informed that the Hasport kit only allowed me to mount the hydro tranny. I was talking about actually using the hydraulic system, this seems as it's still using cable. I wondered why no one said anything about lines or cylinders...
Old Nov 24, 2005 | 04:14 AM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NINE9DC4 &raquo;</TD></TR><TR><TD CLASS="quote">I was informed that the Hasport kit only allowed me to mount the hydro tranny. I was talking about actually using the hydraulic system, this seems as it's still using cable. I wondered why no one said anything about lines or cylinders...</TD></TR></TABLE>
Because the Hasport kit eliminates these. Basically, the Hasport kit converts a hydraulic transmission to cable operation. It includes an actuator that bolts where the slave cylinder bolts that actually disengages the clutch using the cable. If you want to go completely hydraulic, then you are on your own when it comes to using the hydraulic system.
Old Nov 24, 2005 | 07:23 PM
NINE9DC4's Avatar
Default Re: (StorminMatt)
I understand what you're saying, but it's still going to shift like a regular cable tranny, rough as all hell.
Old Nov 25, 2005 | 10:07 AM
88 rex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NINE9DC4 &raquo;</TD></TR><TR><TD CLASS="quote">I understand what you're saying, but it's still going to shift like a regular cable tranny, rough as all hell.</TD></TR></TABLE>
I never had any problems with my cable tranny and haven't had any (other than a bad bearing) in my hydro tranny.
I prefer cable over hydro anyway. More adjustability and better "feel." It's like a direct connection b/w my foot and the tranny.
Old Nov 25, 2005 | 03:17 PM
1QwIkEf's Avatar
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
Default Re: (88 rex)
i have the efb2 hasport kit in my hatch with a hydro gsr trans. the clutch is hard to press cause of my pp. but the kit works great. its hasport. but like said b4 you will not use any of the hydro parts in your car at all. also you don't need to use a DA teg clutch cable
Old Nov 25, 2005 | 03:33 PM
TheBobFather's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 rex &raquo;</TD></TR><TR><TD CLASS="quote">
I prefer cable over hydro anyway. More adjustability and better "feel." It's like a direct connection b/w my foot and the tranny.</TD></TR></TABLE>
I agree
Old Nov 25, 2005 | 06:15 PM
88 rex's Avatar
Default Re: (1QwIkEf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1QwIkEf &raquo;</TD></TR><TR><TD CLASS="quote"> also you don't need to use a DA teg clutch cable</TD></TR></TABLE>
True, but the DA cable allows for more adjustment on the tranny side.
ef9smashing
Jan 28, 2010 06:15 AM
dr4zz
Aug 11, 2009 05:11 AM
TheBetterSol
Jan 6, 2005 07:30 PM
EF9-G'zer
Jun 28, 2004 02:05 AM
som3on3_10
Jun 17, 2004 08:28 PM
