Swap Question: JDM B16A 6th gen to 5th gen
Old Nov 22, 2005 | 12:21 PM
B-SerioUs EGg's Avatar
B A N N E D
Default Swap Question: JDM B16A 6th gen to 5th gen
if i get a swap out of a 6th gen can i use the same mounts to fit it into a 5th gen chassis?
i know the 6th gen will require the rear bracket from the 99-00 SI. the 5th gen needs mounts from a 3rd gen teg.
was wondering if the swap from one gen to the other will require anything else.
Old Nov 22, 2005 | 04:47 PM
typeoneeg6's Avatar
Default Re: Swap Question: JDM B16A 6th gen to 5th gen (Frosty R81)
b series into eg uses a combination of 5th gen civic and 3rd gen integra mounts. you are right you need rear bracket from dc teg. the p28 you have in your hatch you should just get chipped. but i would upgrade to hasport mounts. that way you have all the correct mounts and you will never have to replace them either. one of thaose install and forget type deals.
Old Nov 22, 2005 | 07:04 PM
JDMdelsol9051's Avatar
i just bought a 95 del sol and a 91 integra that is totaled with a b16a in it does anyone know how hard it is to pull out the b16 out of the integra bay? thanks
.BigSexy
Feb 22, 2008 01:42 PM
91EXRMANUAL
Dec 13, 2004 03:44 PM
Greyout
May 6, 2004 08:52 AM
