B18b, do I need to retune??? help please
Old Nov 22, 2005 | 11:43 AM
alghafat424's Avatar
Default B18b, do I need to retune??? help please
I blew up my old engine( which was leaking oil) and in the process of getting another LS engine,,,,my question is,,,,my old setup was tuned at 10 psi, so for the new engine if I turn the boost to 8 psi myself without professional tuning is it going to be fine or not?????
your help is appreciated
Old Nov 22, 2005 | 11:49 AM
M.A.R.C.'s Avatar
Default Re: B18b, do I need to retune??? help please (alghafat424)
i would think the tune would not be off by much but i'd definitaley at least take it to the dyno or throw a wideband on it and make sure it's safe.
vaporboy12's Avatar
i would retune it. the motors may have different compression number.
Old Nov 22, 2005 | 11:55 AM
Default Re: B18b, do I need to retune??? help please (vaporboy12)
There is no good tuners where I am at right now, so staying at lets say 7 psi with the old tuning going to work temporarly or not???
Thanks guys
Old Nov 22, 2005 | 11:57 AM
SOHCD16y8's Avatar
How did your old one blow? If it was from a poor tune then youll only be hurting this motor too.
Old Nov 22, 2005 | 12:09 PM
Default Re: (SOHCD16y8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCD16y8 &raquo;</TD></TR><TR><TD CLASS="quote">How did your old one blow? If it was from a poor tune then youll only be hurting this motor too.</TD></TR></TABLE>
It was leaking oil, not from the old tune because it was tuned by a professional tuner on a dyno
Old Nov 22, 2005 | 12:16 PM
scottishdave's Avatar
I would take the trip to find a pro tuner. You cant skimp on stuff like tuneing. If you get the new motor in turn the boost down and drive to a tuner. Its better to go through a hassle to get it tuned than go through the hassle of blowing anouther motor.
Old Nov 22, 2005 | 12:19 PM
PRELUDE-GT35R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alghafat424 &raquo;</TD></TR><TR><TD CLASS="quote">I blew up my old engine( which was leaking oil) and in the process of getting another LS engine,,,,my question is,,,,my old setup was tuned at 10 psi, so for the new engine if I turn the boost to 8 psi myself without professional tuning is it going to be fine or not?????
your help is appreciated</TD></TR></TABLE>
Need tune big time in order to save your $$$$ in the long run
Old Nov 22, 2005 | 12:30 PM
SOHC_MShue's Avatar
Retune it
Old Nov 22, 2005 | 12:31 PM
SOHCD16y8's Avatar
So your motor blew from leaking oil? My buddies motor leaks oil but it has 200,000 on it? Please elaborate. Also is it the same turbo setup? If so You should be good, just get a wideband and make sure the A/F is safe and the timing is conservative.
Old Nov 22, 2005 | 01:08 PM
JDMisGOOD's Avatar
Re-tune it. What engine management are you using?
Old Nov 22, 2005 | 02:12 PM
B16Civic93's Avatar
Default Re: (JDMisGOOD)
get a wideband and check it for yourself and see if the a/f ratios are good with it, if you dont have a tuner close. and if they do suck well then you now have a wideband and you saved yoruself the hassle and expense of having to swap in another motor. just my .02
boostmywankle
Oct 20, 2007 03:50 PM
blk_EK
21
Dec 26, 2006 09:23 PM
ITS_Dunn
Feb 9, 2006 12:19 PM
hb_rule_b18
Jun 28, 2005 04:03 AM
LsBack
47
Mar 24, 2005 12:44 AM
