jdm k20a (type r) or usdm k20a2?
Old Nov 22, 2005 | 11:37 AM
mugensport9's Avatar
Default jdm k20a (type r) or usdm k20a2?
hmotorsonline is selling em both.
my question is if u were looking into swaping a K into your ej would you get the type r even tho its $1600 more? or is it not worth it?
opinions please
Old Nov 22, 2005 | 11:46 AM
. L i z's Avatar
Default Re: jdm k20a (type r) or usdm k20a2? (mugensport9)
same horsepower i believe.. 220. so it depends if you want to be jdm or not.. i think the jdm has more torque??
Old Nov 22, 2005 | 11:47 AM
SkoundrelUSA's Avatar
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilhondagirl &raquo;</TD></TR><TR><TD CLASS="quote">same horsepower i believe.. 220. so it depends if you want to be jdm or not.. i think the jdm has more torque?? </TD></TR></TABLE>
USDM Type-S is 200hsp. The K20A2 that is, the new one (2005-06 or w/e) is like 201 according to consumerguide...
1600 for 20hsp? Naaahh
+ at least with USDM you know (usually) the exact mileage unlike mystery JDM motors.
Old Nov 22, 2005 | 11:53 AM
Default Re: jdm k20a (SkoundrelUSA)
not the same hp its 20hp difference and i dont know how much tq difference. but it does seem minimal for the price. i guess with that 1600 i could get some nice goodies. *cough hondata cough*
Old Nov 22, 2005 | 11:56 AM
StRoKeD-B16bEj2's Avatar
Default Re: jdm k20a (mugensport9)
but wat about the new type-s motor K20z3 its 210 hp and its USDM
Old Nov 22, 2005 | 11:57 AM
cute little bastard
Default Re: jdm k20a (BLaCkMaNEg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLaCkMaNEg6 &raquo;</TD></TR><TR><TD CLASS="quote">but wat about the new type-s motor K20z3 its 210 hp and its USDM</TD></TR></TABLE>
Not according to the acura site (201) the SAE ratings or w/e must have got chances and the chances of finding a 2005 motor is not likely
Old Nov 22, 2005 | 12:02 PM
Redline96LX's Avatar
* B A N N E D *
Dont get the JDM version. Its meant for japan, so the fuel is different and ****, and you will have emission issues if you live in california (BARing) and no, you cant square the price difference. You got the K series. For that extra cost, you can get the ECU tuned, and since you'll be putting in a after market header and intake (aftermarket intake will be cheaper anyway, get a tube off ebay and a amsoil or K&N filter) and that alone will give ya another 20hp from stock in the RSX. Theres your 20hp, get like a spoon muffler so the car sounds great, and you dont have to get a damn japanese version.
Old Nov 22, 2005 | 12:04 PM
Default Re: jdm k20a (Redline96LX)
i did see something about 2005 haveing 10 more hp. but likelyhood that i can find the motor is slim to none. and i will be moving to cali. so sounds like usdm is my choice.
Old Nov 22, 2005 | 12:12 PM
93CX's Avatar
^^ you're defeating your own point. or you could get the extra 20hp and add an ebay intake, high quality header, and spoon muffler and have 40 extra hp. its all up to the buyer
Old Nov 22, 2005 | 12:13 PM
Slow EJ8's Avatar
I though 05/06 RSX-S was K20z1 and the FG2 (06+ Si) was K20z3 w/ 197hp (SAE rev 8/04)
Old Nov 22, 2005 | 12:46 PM
808_si's Avatar
If you are going to swap and do nothing else, get the k20r, if you are going to mod the thing, just get the usdm. No sense buying the jdm if your'e going to swap cams etc out later...
Old Nov 22, 2005 | 02:14 PM
Earthworm Jim's Avatar
Depends on what you want to do. Honestly, if you're going to change the head at all then I'd go USDM, it doesn't matter anyway. Leaving it stock, then go JDM. Unless it's a straight and they're aren't any cops around you'll never need a sixth gear anyway
Old Nov 22, 2005 | 02:29 PM
2000DX's Avatar
Default Re: jdm k20a (EH_Squad_Member54)
I believe you will get a LSD tranny with k20a (type-r).
Old Nov 22, 2005 | 02:41 PM
Default Re: jdm k20a (2000DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000DX &raquo;</TD></TR><TR><TD CLASS="quote">I believe you will get a LSD tranny with k20a (type-r).</TD></TR></TABLE>
Phantom works better
Old Nov 22, 2005 | 07:14 PM
2000DX's Avatar
Who would use a Phantom...
not to advertise or anything, but if you're looking for K-Series information, you should go to k20a.org
Old Nov 22, 2005 | 07:18 PM
97ShLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000DX &raquo;</TD></TR><TR><TD CLASS="quote">Who would use a Phantom...
not to advertise or anything, but if you're looking for K-Series information, you should go to k20a.org </TD></TR></TABLE>
Especially if they're shelling out that kind of money anyway.
Old Nov 23, 2005 | 02:52 AM
6SPD_EK's Avatar
Default Re: jdm k20a (lilhondagirl)
lets cut all the BS out of this thread....
WRONG
if all that matters to you is hp who cares about better gearing, LSD, better Intake manifold, better cams, higher comp pistons (than k20a2)
for differences of '05+ RSX-S aka k20z1 see below
they changed methods of rating HP (SAE) this year the 201 this year is the same as the 210 last year
CORRECT!!!!
differences between motors
k20a2 '02-'04 RSX-S (PRB IM, Type S (PRB) cams)
k20z1 '05+ RSX-S (better cams (PRC=ITR), PRC IM, better FD gearing) NOT directly K-PRO compatiable see ---&gt; - 2005-2006 RSX K-pro (manual transmission with adapter harness and modified 02-04 ecu)
k20z3 '06+ si (RBC IM, ITRish cams, LSD) NOT K-PRO compatiable - throttle by wire I believe
jdm K20a (R) (higher compression pistons, LSD, better FD gearing, PRC IM, ITR cams)
as for the hp ratings - they changed the method used this year the si's 197hp is basically the same as '05+ RSX-S's 210... the RBC IM (euro accord type r/'06+ Si) is supposedly better the the PRC (ITR) IM which is better than the PRB (02-04 RSX-S)
their are plently of jdm k20a's tuned w/k-pro to run on **** gas & do it well
price difference:
better gearing (FD) $500 est
better cams (ITR) $500 est
LSD (ITR) $500 est
higher compression pistons $500
intake manifoild $300
does that justify the price difference - yes in my opinion
also if you go with aftermkt LSD go quaife not phantom
as the last guy stated go to http://www.k20a.org this has all been covered
I have a jdm k20a type r (from passwordjdm.com) so i have a biased opinion
teaser pic - hytech adj. length header
Old Nov 23, 2005 | 03:09 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: jdm k20a (adirondackR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adirondackR &raquo;</TD></TR><TR><TD CLASS="quote">teaser pic - hytech adj. length header
</TD></TR></TABLE> DTR
Old Nov 23, 2005 | 07:00 AM
Default Re: jdm k20a (litterbox)
yo just wonderin i see all these k20's for sale on ebay for like 2,000 for complete swap is that just like a scam or u can actually get one for 2,000 because if so im sellin mah type-r and getting one lol
Old Nov 23, 2005 | 07:02 AM
cute little bastard
Some people have been selling them for a low price, but I'm too scared to buy a motor off ebay.
Old Nov 23, 2005 | 07:09 AM
Slow EJ8's Avatar
You could get a K24... I have seen them going cheep(er) compared to the K20a/K20a2. Plus more torque
Old Nov 23, 2005 | 09:10 AM
thnx adirondackR
and thanx to everyone for all the great input
Old Nov 23, 2005 | 09:24 AM
6SPD_EK's Avatar
Default Re: (mugensport9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugensport9 &raquo;</TD></TR><TR><TD CLASS="quote">thnx adirondackR
and thanx to everyone for all the great input</TD></TR></TABLE>
no problem
as for ebay - stay away unless its a reputable seller with good feedback - make sure feedback is from BUYERS & recent
many motor swaps listed on ebay have type r in title of listing but its not an actual type r swap...many others that are type r swaps are new sellers - asking pmt be wired to an off shore acct etc...I would not touch those. stay with a reputable shop or ebay seller - do you research. also realize how expensive this swap is (especially done right) you don't wanna know how much i have spent on mine (still uninstalled) - I have extras like toda flywheel (8.1 lb) exedy clutch, RBC intake mani (needs to be modified to fit k20a/a2) RSX-S cluster & custom wiring for cluster (water temp - don't ask), Karcepts shifter kit, aftermkt rad & slim fan, etc...
Old Nov 23, 2005 | 09:27 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">Some people have been selling them for a low price, but I'm too scared to buy a motor off ebay. </TD></TR></TABLE>
Don't I learned that one the hard way.
<FONT SIZE="6">Just get the motor from Hmotors</FONT> but know what you have planned for it before you make your purchase, but the way, what do you have planned? I haven't been paying attention
Old Nov 23, 2005 | 09:51 AM
i would never buy a motor off ebay. im 20 now and when i was 16 i have 4gs to spend. i meet a guy here on HT talked to him everyday on aim all day long about just life bla bla. he completly befriended me he claimed he worked for inline pro bla bla i bought a b16rex and never got it... ive been away from the scene for a while now. but im going into the coast guard and ill have like near 10K to build a car.+2k a month to throw at it if i want
so im gonna buy a cheap ej. strip it to the bone. throw on a lip and skirts n things and sent it to get painted a really dark silver. and im gonna k20 it. at first just hondata,header,intake,exhaust.nothign crazy, real streetable. i wanna be able to know that if i wanted i could drive cross country and not be worried.
and some tein coilovers, some bride seats, and some black rota gt3s.
basicly im going to rebuild everything. and have a new ej with a newish motor and the car will be my daily hot rod. ill take pictures durring the whole process.
i promise u guys will like it
