sprayd a lil too much
Old Nov 22, 2005 | 10:35 AM
92eg6's Avatar
Default sprayd a lil too much
I have a b16, with a NOS single fogger, the car had vpower plugs, the nitrous set at full throttle and the timing was reatarded -2. The other night i sprayd on a run and my motor is now smoking and knocking. The car idles perfectly fine and does not overheat but it is letting off alot of white smoke. Im guessing i might have blown the headgasket but am not sure since the engine is not overheating. I have no time to take it to the shop being that i am in school, hopefully i can find time this weekend and have a compression test done and hopefully diagnose the problem.
Modified by 92eg6 at 10:14 PM 11/22/2005
Old Nov 22, 2005 | 10:38 AM
TsukubaDreams's Avatar
blew your head gasket proably... fix immeadietly and dont drive
Old Nov 22, 2005 | 10:40 AM
92eg6's Avatar
Default Re: (TsukubaDreams)
figurd that too but wouldnt it overheat? I know its a vague explination but i go to school full time and also work full time, so i need my car and do not have money to take to the shop, i also retarded timing..did everything to prevent it but it blew neway
Modified by 92eg6 at 10:44 PM 11/22/2005
Old Nov 22, 2005 | 10:41 AM
your choise but its going to cost way more when your motor goes kaboom
Old Nov 22, 2005 | 11:29 AM
Archidictus's Avatar
Unceasing Measure
Default Re: (92eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92eg6 &raquo;</TD></TR><TR><TD CLASS="quote">...did everythin to prevent it but hapnd neway </TD></TR></TABLE>
Everything but not be retarded. A commonly overlooked bit of the equation.
Old Nov 22, 2005 | 11:34 AM
. L i z's Avatar
Default Re: (92eg6)
i believe you can get a new head gasket for not much and do it yourself.. not too hard. its cheaper than your whole motor just blowing up or seizing
Old Nov 22, 2005 | 11:58 AM
postman's Avatar
Default Re: sprayd a lil too much (92eg6)
where is the knock coming from
Old Nov 22, 2005 | 11:59 AM
BiG Chris's Avatar
yea ive had the same problem before where i had the same symptoms, it turned out to be that i a portion of one pistons has melted right near rings. this is what it looked like....
OHH if you want a good head gasket i got a extra one for sale, its a cometic MLS gasket and its .074" thickness it will help if you want to squeeze more with a b16
Old Nov 22, 2005 | 12:21 PM
kaoss_11's Avatar
B A N N E D
i would go oem headgasket
Old Nov 22, 2005 | 12:50 PM
Evil-EK's Avatar
Default Re: (kaoss_11)
I had the same thing happen to my b16 but I pulled the head off and it was a piston and sleeve wall had a hole in them.
Sounds like NITROUS JUST OWNED YOU!!!
Old Nov 22, 2005 | 01:08 PM
Eyal 951's Avatar
Default Re: (BigBlockH22atch)
That motor is not gonna last much more. Either rebuild (knock means likely rebuild, not just HG) or swap. I'll trade you my d15b8.
Why the hell would you expletive with it knowing the consequences, if you don't have the money/time to fix if you expletive up?
Old Nov 22, 2005 | 02:28 PM
Redline96LX's Avatar
* B A N N E D *
Default Re: (Eyal 951)
This is a webpage forum, not an IM box. Talk in english man. I have no idea what you want.
Old Nov 22, 2005 | 02:31 PM
cybergreencivic's Avatar
did you have a FPR on your motor? j/w cause i didnt have one and i ran lean and broke a valve, and i dont know if something like that maybe happened to you. but you deffinetly wouldve know if you broke a valve, but just something else you may want to get if you fix your motor and still spray.
EJ1 wilcox's Avatar
Default Re: (92eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92eg6 &raquo;</TD></TR><TR><TD CLASS="quote"> i go to skool full time and also work full time</TD></TR></TABLE>
Whatever you do, don't drop out of school. You REALLY need it. I can barely understand what you are trying to say, and that's after I read your post a few times over.
Old Nov 22, 2005 | 02:43 PM
spoonracer84eg's Avatar
Default Re: (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">
Whatever you do, don't drop out of school. You REALLY need it. I can barely understand what you are trying to say, and that's after I read your post a few times over. </TD></TR></TABLE>
Old Nov 22, 2005 | 06:28 PM
92eg6's Avatar
Trust me schools first and hopefully six years from now when im your age i wont be on honda- <U>tech</U> posting usless smart *** comments. I edited my first post just for you because i would rather have helpful posts then a bunch of tools makin useless ones. I need my car, dont have mommy and daddy to help at all, so any help is appreciated. Thank you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cybergreencivic &raquo;</TD></TR><TR><TD CLASS="quote">did you have a FPR on your motor? j/w cause i didnt have one and i ran lean and broke a valve, and i dont know if something like that maybe happened to you. but you deffinetly wouldve know if you broke a valve, but just something else you may want to get if you fix your motor and still spray. </TD></TR></TABLE>
No i dont have a fpr, car is runnin and idiling fine, just a lil knock and alot of white smoke.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">
Everything but not be retarded. A commonly overlooked bit of the equation.</TD></TR></TABLE>
lol you cut off my post right before i said i retarded the timing. tried being safe, its my one and only car.
Modified by 92eg6 at 11:28 PM 11/22/2005
Old Nov 22, 2005 | 06:48 PM
eg360B's Avatar
Default Re: (92eg6)
Trust me schools first and hopefully six years from now when im your age i wont be on honda- <U>tech</U> posting usless smart *** comments. I edited my first post just for you because i would rather have helpful posts then a bunch of tools makin useless ones. Im 19 in my third year of college and need my car, dont have mommy and daddy to help at all, so any help is appreciated. Thank you
.</TD></TR></TABLE>
DAMNN that was COLD BLOODEDD.. Lol.
Old Nov 22, 2005 | 06:51 PM
xEnderx's Avatar
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">Everything but not be retarded. A commonly overlooked bit of the equation.</TD></TR></TABLE>
Oh god, that is hilarious.
Seriously though...sounds like a blown head gasket. I wouldnt' drive it if I were you.
If you hav eto have your car to get to school then what the expletive were you doing spraying it anyway?
Old Nov 22, 2005 | 06:53 PM
VRD^sam's Avatar
Default Re: (Byrd Gang 021)
Old Nov 22, 2005 | 06:59 PM
92eg6's Avatar
Default Re: (boostin_elf)
yea im not drivin it now, im sprayin cause its FUN!! lol..learned my lesson now....FORGED internals!! new headgasket and im bak
Old Nov 22, 2005 | 07:08 PM
FERIOkid's Avatar
Default Re: (92eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92eg6 &raquo;</TD></TR><TR><TD CLASS="quote">figurd that too but wouldnt it overheat? I know its a vague explination but i go to school full time and also work full time, so i need my car and do not have money to take to the shop, i also retarded timing..did everything to prevent it but it blew neway
Modified by 92eg6 at 10:44 PM 11/22/2005</TD></TR></TABLE>
not if it was a slow leak, it will eventually get bigger and you will notice the gauge going higher and higher, daily. Happened to my DX motor.
Old Nov 22, 2005 | 07:13 PM
92eg6's Avatar
Default Re: (I :heart: 4 DOORS)
oh ok, thanks for those of you who actually helped, bought an LS longblock just in case but i want to at least run the b16 until im able to build the LS. so im gonna try a compression test and if all is well im gonna change the headgasket and hopefully will run fine.
Anthony's Avatar
Mr. Fuch-yu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92eg6 &raquo;</TD></TR><TR><TD CLASS="quote">Trust me schools first and hopefully six years from now when im your age i wont be on honda- <U>tech</U> posting usless smart *** comments. I edited my first post just for you because i would rather have helpful posts then a bunch of tools makin useless ones. Im 19 in my third year of college and need my car, dont have mommy and daddy to help at all, so any help is appreciated. Thank you</TD></TR></TABLE> Dude, I'm 20 and in my 3rd year of college and I post stupid smart *** comments all the time. Point being, if you would learn to ******* type, no one would have called you on anything. Also, do me a favor, don't tell anyone else you are in your third year of college. I just said that I'm in my 3rd year and I don't want anyone thinking that I'm as dumb as you. Nothing personal, but people like to stereotype.
-Red
Old Nov 22, 2005 | 07:26 PM
92eg6's Avatar
Default Re: sprayd a lil too much (nitrared)
what?? i was in a rush on my way to work, just got back seen a dumb comment, so i edited my post and retyped it to make it more understandable to not offend anyone with abreviations or slang and hopefully this way somone will help. no offense but i really cant stand ethugs or noobs, maybe the pointless comments is exactly why other forums hate this one, ex.b20vtec. sorry if i sound bitter at all, but i only post on the technical forums when i need help or can help, but i see its changed.dude.
Old Nov 22, 2005 | 07:45 PM
Anthony's Avatar
Mr. Fuch-yu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">Whatever you do, don't drop out of school. You REALLY need it. I can barely understand what you are trying to say, and that's after I read your post a few times over. </TD></TR></TABLE>Ok. This dude is trying to get you to help him help you. Yeah he was a smart-***, but if the shoe was on the other foot, you would have been too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92eg6 &raquo;</TD></TR><TR><TD CLASS="quote">Trust me schools first and hopefully six years from now when im your age i wont be on honda- <U>tech</U> posting usless smart *** comments. </TD></TR></TABLE> This is where you got your panties in a bunch at the same time being a smart-***.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitrared &raquo;</TD></TR><TR><TD CLASS="quote"> Dude, I'm 20 and in my 3rd year of college and I post stupid smart *** comments all the time. Point being, if you would learn to ******* type, no one would have called you on anything. Also, do me a favor, don't tell anyone else you are in your third year of college. I just said that I'm in my 3rd year and I don't want anyone thinking that I'm as dumb as you. Nothing personal, but people like to stereotype.</TD></TR></TABLE>This is where I am showing you (in a smart-*** manner) that age is not even a factor in smart-*** comments. They come from people of all ages. Plus, I like being a smart-***. It warms my heart.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92eg6 &raquo;</TD></TR><TR><TD CLASS="quote">no offense but i really cant stand ethugs or noobs</TD></TR></TABLE> I'm not an ethug or a n00b. I was just making a point. No hard feelings. Consider this a free bump.
-Red
