Cluster Question....
Old Nov 22, 2005 | 01:36 AM
gameboi's Avatar
Default Cluster Question....
i dunno if this has been posted but im sure, does anyone know if the 99-00 si cluster will fit the eg coupe? i knoe its possible but whats the trouble i have to go through....
Old Nov 22, 2005 | 01:49 AM
lazie's Avatar
Default Re: Cluster Question.... (gameboi)
it will work but there are a few problems. the wiring harness is completley differnt you'll have to find a wiring diagram that shows which wire goes from your eg wireing harness to the si plugs for the cluster. also the cluster dosnt completly line up in the eg, most people use zip ties to keep it in there or you can fashon your own bracket in there. i know that dc2 cluster swaps for the eg are alot more common. try a little searching and i'm sure you'll come across something.
akarooster
Aug 24, 2012 07:05 AM
BubLBack
12
Sep 7, 2006 09:23 PM
gameboi
Nov 18, 2005 06:34 PM
daidilus
Nov 22, 2004 09:21 PM
