Can ECU's Go bad?
Old Nov 22, 2005 | 12:07 AM
deanh8's Avatar
Default Can ECU's Go bad?
I'm about to buy a PR4 ECU for my B18 in EF swap, from a local guy. The problem is its really cheap and I was wondering if it might be defective somehow.
Can ECU's go bad? Any way to check to make sure its working?
Old Nov 22, 2005 | 06:10 AM
Kendall's Avatar
Yes they can go bad. Plug it up and try and start the car to check it.
Old Nov 22, 2005 | 08:01 AM
nonPOINT's Avatar
Default Re: (Kendall)
Typicly if a PCM goes bad it is due to a bad grounding
Old Nov 22, 2005 | 04:03 PM
deanh8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">Yes they can go bad. Plug it up and try and start the car to check it.</TD></TR></TABLE>
The thing is, Im collecting parts for a swap. I dont have the motor or anything in the car yet. So how would I check?
Old Nov 22, 2005 | 06:32 PM
bdavis's Avatar
Default Re: (deanh8)
usually its a capacitor that fries. look at the big round things sticking up, the largest ones on there and see if they have leaked some stuff around. its like green and brownish usually. ive had them go bad and its not the caps, but caps are the most common. it will smell bad too , some say like rotten eggs.
this happens a lot on dsm computers. i have successfully fixed a couple with new caps
Old Nov 22, 2005 | 06:36 PM
deanh8's Avatar
Default Re: (random-strike's MOM)
any pics of what your talking about? Im lost
Old Nov 22, 2005 | 07:56 PM
SVOboy's Avatar
Relinked from pgmfi.org, cuz I figure you're prolly not registered there.
Old Nov 22, 2005 | 08:32 PM
deanh8's Avatar
Default Re: (SVOboy)
so if it dosn't look all fucked up like that one it should be good right?
Old Nov 22, 2005 | 08:33 PM
V8MeatHead's Avatar
From: Holley 4053, carb 406 stroker anal Luber, Fag
ya saw that there. That's been posted on here too but that was a while back. Sometimes you can't tell. You may have burned up a IC as well those don't usually show. Even sometimes resistors you can't tell. Traces may be lifted. Shorts may be there. Who knows.
Old Nov 22, 2005 | 08:46 PM
V8MeatHead's Avatar
Default Re: (V8MeatHead)
One of the only ways to tell if it might work, is to throw it into the car and see if it throws any cels.
Addicted 2 Adrenaline
Jul 8, 2007 03:20 PM
Problemo
Feb 26, 2006 03:33 PM
the soL that could
Feb 1, 2006 10:29 AM
SNsLude
Jan 26, 2006 07:08 PM
hbkid92591
Feb 20, 2005 05:59 PM
