where to find window molding...
Old Nov 21, 2005 | 10:03 PM
lowbOOsted's Avatar
I'm a Jackass
Default where to find window molding...
well it rained all day today and i decide to go see my girl and i notice a nice pool forming in the hatch area of my 1991 crx.... where is the best place to buy replacement weather stripping??? (i guessing this is the problem) -justin-
Old Nov 22, 2005 | 03:36 AM
Autoworks's Avatar
Default Re: where to find window molding... (CB1)
good ol' Honda Dealership
or I think you can go to http://www.hondaautomotiveparts.com
Old Nov 22, 2005 | 03:49 AM
Pee Wee's Avatar
Default Re: where to find window molding... (Autoworks)
https://www.hondaautomotivepar...HIELD
Old Nov 22, 2005 | 09:30 PM
lowbOOsted's Avatar
I'm a Jackass
preciate the help guys
Old Nov 22, 2005 | 09:51 PM
mekanism's Avatar
If you have an Si then you should try clearing the drain tubes that run from the sunroof. If its not that try pulling your rear interior out and place a hose on your roof to see where water is coming in.
Old Nov 23, 2005 | 06:19 AM
lowbOOsted's Avatar
I'm a Jackass
Default Re: where to find window molding... (mekanism)
i have a DX so no luck on the sunroof... however the hose idea sounds good
Old Nov 23, 2005 | 10:48 AM
slow_rex_will's Avatar
Modified by slow_rex_will at 2:27 PM 11/24/2005
Old Nov 23, 2005 | 01:15 PM
Newark Built's Avatar
* B A N N E D *
Default Re: where to find window molding... (slow_rex_will)
blow some compressed air thru the drain holes....not that shitty air in a can **** for your computer.....go to a shop with a nice compressor...mine is set to 140psi
Gatta keep it that high to keep up with the CNC
Old Nov 23, 2005 | 03:37 PM
Default Re: where to find window molding... (Newark Built Kandy SiC-RX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newark Built Kandy SiC-RX &raquo;</TD></TR><TR><TD CLASS="quote">blow some compressed air thru the drain holes....not that shitty air in a can **** for your computer.....go to a shop with a nice compressor...mine is set to 140psi
Gatta keep it that high to keep up with the CNC </TD></TR></TABLE>
Thanks!
donniedarko
Apr 8, 2011 09:29 AM
drew2
Jul 23, 2006 10:08 PM
Dwight Schrute
Jan 24, 2004 03:25 PM
yusoslo
12
Oct 22, 2003 09:03 PM
crXtreme_girl
10
Jan 28, 2003 05:24 AM
