Help!! Problem with my VSS(speed sensor)
Old Nov 21, 2005 | 06:26 PM
dingle's Avatar
Default Help!! Problem with my VSS(speed sensor)
Recently my speed sensor went out, so i went & bought a new one from honda installed it & it still doesn't work.
Problems:
cluster dims in & out
doesnt idle correctly
no vtec
no speedo
stock jdm b16(obd1)
I have no idea what could be wrong, nobody that i know could help me!!
Old Nov 21, 2005 | 06:32 PM
cdizzle's Avatar
Dam how much was that??? jus curious
Old Nov 21, 2005 | 06:37 PM
dingle's Avatar
$97
Old Nov 21, 2005 | 06:44 PM
tpr's Avatar
tpr
Default Re: Help!! Problem with my VSS(speed sensor) (dingle)
Sounds like a bad ground. Check to be sure all the grounds, inculding the one at the thermostat housing as it feeds many engine sensors to a common ground point/plane. The instruments lights dimming could be any of the numerous under dash ground points. My money is an engine bay ground problem.
mkt_720
Nov 19, 2010 03:56 PM
EFRue57
Jun 28, 2010 01:54 PM
speed.freak
Jun 8, 2005 01:40 PM
.Beaver
May 1, 2005 12:16 PM
DuNkiN
Aug 8, 2001 08:21 AM
