N00B Question About Wiring The Lights On My Guages PLEASE HELP
Old Nov 21, 2005 | 05:16 PM
93CharcoalHatch's Avatar
Default N00B Question About Wiring The Lights On My Guages PLEASE HELP
heyyy.. i just bought some gauges with a triple a-pillar pod and was wondering what i can safely wire their lights into.. i need a constant 12v for memory, a switched 12v to turn them on, and a ground.. can someone please help me with what i can wire into or how to wire them up? Thanks Alot in advance!!!
Old Nov 21, 2005 | 05:35 PM
Default Re: N00B Question About Wiring The Lights On My Guages PLEASE HELP (93CharcoalHatch)
Old Nov 21, 2005 | 05:40 PM
SuperSteve737's Avatar
Wow, only 19 minutes before you bump your own ****, huh?
Constant can be your horn, switched can be your radio, and the ground to a bolt touching metal somewhere.
Old Nov 21, 2005 | 06:08 PM
Default Re: (SuperSteve737)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSteve737 &raquo;</TD></TR><TR><TD CLASS="quote">Wow, only 19 minutes before you bump your own ****, huh?
Constant can be your horn, switched can be your radio, and the ground to a bolt touching metal somewhere.</TD></TR></TABLE>
wow very percise.. was getting low on the page so i bumped lol
Old Nov 21, 2005 | 06:11 PM
Yeah, now go and see if your stuff works.
Old Nov 22, 2005 | 03:16 AM
im looking for something i wont blow fuses wiring into. i wired into my radios constant 12v switched 12v and ground and i blew the back up fuse in the engine bay.. any other ideas? thanks alot
Old Nov 22, 2005 | 04:48 PM
Default Re: (93CharcoalHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CharcoalHatch &raquo;</TD></TR><TR><TD CLASS="quote">im looking for something i wont blow fuses wiring into. i wired into my radios constant 12v switched 12v and ground and i blew the back up fuse in the engine bay.. any other ideas? thanks alot</TD></TR></TABLE>
Old Nov 23, 2005 | 06:26 PM
Old Nov 23, 2005 | 07:28 PM
Sorry about popping your fuses.
What gauges did you get and from what company?
Old Nov 24, 2005 | 06:44 PM
lmao i got some **** gauges on ebay just looking to wire up the lights for them .. they are like 7 color glow ones.. like i said theres a constant 12v a switched 12v and a ground any ideas what to wire into? Thanks Alot !
Old Nov 25, 2005 | 07:36 AM
Old Nov 25, 2005 | 09:12 AM
98coupe's Avatar
From: NOVA, but OC MD for the summers, 10th St., Tyson R.I.P, USA
Check your ground wire. Where did you ground it to?
Old Nov 25, 2005 | 02:05 PM
Default Re: (98coupe)
when i blew the fuse i used the constant 12v the switched 12v and the ground all from the radio
Old Nov 25, 2005 | 02:33 PM
Oh well ****, that's why it popped. The backup fuse is also the radio fuse. You probably had too much juice flowing through everything. Try again, but do what I said.
Old Nov 25, 2005 | 03:35 PM
william72364's Avatar
it is going to pop the radio backup fuse every time because it is only meant to carry enough juice for the radio either increase the fuse rating or wire it straight to the battery and put a fuse in the line
Old Nov 25, 2005 | 03:43 PM
Old Nov 25, 2005 | 04:19 PM
-JSpecEk*9-'s Avatar
Default Re: (william72364)
........i smell Rice!!
Old Nov 25, 2005 | 06:47 PM
Default Re: (JDMEK-9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMEK-9 &raquo;</TD></TR><TR><TD CLASS="quote">........i smell Rice!! </TD></TR></TABLE>
alrighty
Old Nov 26, 2005 | 04:58 AM
Old Nov 28, 2005 | 04:41 PM
Old Nov 29, 2005 | 05:14 PM
Old Dec 1, 2005 | 03:20 AM
god damn december already..
Old Dec 1, 2005 | 03:39 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
If you don't know what your doing, your going to pop fuses.
You can get everything at the fuse box, or the ignition harness.
Old Dec 6, 2005 | 08:34 AM
if i run a constant 12v a switched 12v (using an actual switch) and a ground straight from the battery will it kill my battery ? ? ?
Old Dec 6, 2005 | 10:22 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CharcoalHatch &raquo;</TD></TR><TR><TD CLASS="quote">if i run a constant 12v a switched 12v (using an actual switch) and a ground straight from the battery will it kill my battery ? ? ?</TD></TR></TABLE>
