idle problem
Old Nov 21, 2005 | 04:10 PM
jdm4dr's Avatar
Default idle problem
92 civic cx with 97 jdm type r . ive had it for a wile.i did the swap myself and got it from a friend who had the swap in his carand was having the same problem in his car also. i replaced the idle air control motor 2 times thats not the problem. tryed different ecu's .. i dont think its a vacuum issue its not surging up and down just goes to around 3000 and stays there..i had a 97 gsr motor in it before the type r with no idle problems. so at a stop the car idles perfect , when i start to drive it jumps up to about 3000rpm.. when i come to a complete stop it returns to perfect idle... but when it idles at a stop it makes a humming noise (low) from my intake.. i know a decent amount about motor swaps and so do alot of my friends but we are baffled.. if anyone can help let me know...
thanks..
jdm type r , and type r ecu with obd1 to obd2 pig tail..
Old Nov 21, 2005 | 04:48 PM
jdm4dr's Avatar
anyone?
Old Nov 21, 2005 | 04:51 PM
POE's Avatar
POE
do u have a FITV? its undernieth the TB. if so take of the cap, which is help by 2 10m bolts then screw in the plastic peice, surrounded over a ball baring
Old Nov 21, 2005 | 04:55 PM
jdm4dr's Avatar
FITV?
Mattcheww
Feb 7, 2009 08:11 PM
jdm4dr
Nov 23, 2005 12:39 PM
