2.5" too much for stock GSR?
My friend has a 01 GSR and is looking into a header/exhaust combo. She would like to (key words there) eventually go all out NA on it, but not sure that she will in the future (her money tends to go elsewhere). She doesn't want to get a setup now and have to change it out later for another one. So, she's deciding between a normal header (2" collector) w/ her stock 2" cat and normal 60mm cat-back exhaust -OR- a 2.5" collector header (probably DC JDM), 2.5" cat, and custom 2.5" cat-back. I told her the 2.5" setup would be best when she builds up her motor, but wasn't sure if it would be too much for her otherwise stock (except for intake) GSR now. She has no idea when she'll do more stuff to it (cams, headwork, resleeve block...haha, it's fun to influence friends!), but doesn't want what she gets now to hamper performance now or require changing later. So, is 2.5" all the way thru too much for a stock GSR? Thanks.
i would try to keep it 2.25 because of back presure concerns, honda's hate not having back presure. But for all out track use a 2.5 is fine.
Just what i have noticed.
thanks guys for the replies.
I would say spend the $$$ elsewhere first, springs/shocks, cams/gears, and just get an ITR catback and JDM header. It will take some serious mods before she realizes the gains from 2.5 in all the way through. Just my 2 cents.
I have two exhaust and switch between street exhaust and track exhaust. One's 2.25 and the other 2.5. I find the 2.25 is a lot better in the city, more mid range and low range pull, the other (2.5) i don't fell a thing till 8000. But my car is moded different so. But this is the rule of thumb i use, unless your forced you don't need a big dia. pipe.
M@
Jul 26, 2005 06:38 PM
