-Quick H-T... I need help- My Car wont start!
Old Nov 21, 2005 | 02:47 PM
KeithsDAteg's Avatar
Default -Quick H-T... I need help- My Car wont start!
Well as stated above my Car wont start.
My Car:
93 4dr Integra
I/H/E
This morning I went out to start up my car, and as usual... I started right up.
Drove all the way to work, ran like a top. It was sprinkling.
I work all day while it is raining on and off.
5:30 Rolls around , as does the darkness of the night. I get in my car, and all I get is crank, crank, crank...
I do know that the fuel pump is priming and the main relay is clicking on.
I pulled a spark plug wire from the distibutor. I held it close enough to see it was getting spark. I couldnt see any kind of fire.
Please help me H-T!
Any Comments will be greatly appreciated.
Old Nov 21, 2005 | 03:02 PM
Somebody has to know something.
Bump
Old Nov 21, 2005 | 03:15 PM
Circuit Star-29's Avatar
Default Re: (KeithsDAteg)
Check your distributer. A co-worker with a DA had the same problems with her car as you are. It ended up being the igniter, even though there was spark.
Old Nov 21, 2005 | 03:20 PM
Default Re: (C-speed racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C-speed racer &raquo;</TD></TR><TR><TD CLASS="quote">Check your distributer. A co-worker with a DA had the same problems with her car as you are. It ended up being the igniter, even though there was spark.</TD></TR></TABLE>
Dude thanks for the help. All I had to work with was a keychain flashlight, a mini screwdriver, and the ******* rain.
I will check the coil and the ignitor tomorrow. I had to leave my car there. Im taking some tools tomorrrow and working on it on lunch break.
Anything else to help me??
Old Nov 21, 2005 | 03:21 PM
It is my ******* luck for my car to not start, then the damn search server be down.
:screams at the top of his lungs:
Old Nov 21, 2005 | 03:34 PM
hahahaa...
Old Nov 21, 2005 | 03:53 PM
Bump
Old Nov 21, 2005 | 04:10 PM
Come on H-T I know you are better than this.
Old Nov 21, 2005 | 05:00 PM
ttt
Old Nov 22, 2005 | 12:04 AM
Default Re: (MormonBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MormonBoy &raquo;</TD></TR><TR><TD CLASS="quote">Take your whole distrubutor out and take it to some autostore to have the ignition coil ohms checked.
my cars currently not running because of the same problem and ICM. fo sho!</TD></TR></TABLE>
I have a mutlimeter, I was planning on checking them myself. Thanks for the help.
Old Nov 23, 2005 | 09:02 AM
Well I tested my Ignition Coil, and I believe that I found the culprit.
My Ohm readings were
10.2 and
00.0
If those numbers are correct then I believe that I have a bad ignition coil.
Old Nov 23, 2005 | 04:49 PM
Replaced the Ignition Coil and then she started right up.
Thanks guys for Your help
Old Nov 24, 2005 | 09:17 AM
No problem....IZZ VOT WE DOO...
crist488
Feb 10, 2010 12:58 PM
khoalizzle
Sep 10, 2008 10:51 AM
fwdftw
52
Sep 5, 2006 11:31 PM
89sicivic
15
Jun 1, 2006 07:51 PM
