swaybar links help
The 92 accord im working on had no sway bar rubber bushings and i have the new ones and washers but i dont know what order and direction to put them. Can someone post a pic?
Front and rear sway bars missing?!.. daaaaanm...
There should be "visible" screws threads underneath the car, when you put the sway bar under the car.... 2 of the bushing sort of "U" shape connect the bar to the car, but I'm not sure how the other ones work.
I don't know man.... where did you get the picture from????
That doesn't look quite well... there should not be so many bushings like that....
Shouldn't it be only one?!
Somebody help this guy out.....
Not to thread jack, but I've got a similar question...
Trying to choose the right size 'sway bar end link bushings' from energy suspension. They look exactly like the bushings and washers in zach1288's picture. That's not where they go do they??
http://www.hondaautomotivepart...R+ARM
Here's a diagram for my 99 coupe.
There are eight of these in a pack, but I'm not sure if they will all be used. I could use the inside diameter, the outside diameter, nipple's outside diameter, and the thickness. Any of this info would be awesome! Again, sorry if I jacked your thread... Bump??
proracer718
Suspension & Brakes
Nov 14, 2013 04:26 PM
phil_lt1
Nov 8, 2009 08:33 PM
