Suspension & Brakes Theory, alignment, spring rates....
tell me about this dyno?
Old Nov 21, 2005 | 12:48 PM
MSchu's Avatar
My Name is Nobody
Default tell me about this dyno?
Schu
Modified by MSchu at 8:29 PM 11/21/2005
Old Nov 21, 2005 | 04:33 PM
slammed_93_hatch's Avatar
Default Re: tell me about this dyno? (MSchu)
it would be nice if the graph was more focused on the relavent range rather then having alot of not need space, that would also give you a better idea of what the lines look like.
there appears to be little difference between max and min on the bumb, but more on the rebound side. Are bump and rebound done on the same adjustment? again it would be nice to a more of a relivent range.
Old Nov 21, 2005 | 07:06 PM
MSchu's Avatar
My Name is Nobody
Default Re: tell me about this dyno? (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">it would be nice if the graph was more focused on the relavent range rather then having alot of not need space, that would also give you a better idea of what the lines look like.</TD></TR></TABLE>
Old Nov 21, 2005 | 08:01 PM
2812's.
What are they valved for spring rate wise?
Old Nov 22, 2005 | 06:57 AM
MSchu's Avatar
My Name is Nobody
yeap 2812's... valved for 10k ish rates
Old Nov 22, 2005 | 07:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MSchu &raquo;</TD></TR><TR><TD CLASS="quote">yeap 2812's... valved for 10k ish rates </TD></TR></TABLE>
first time i have ever heard of koni's spring rate vavling used in metric terms, not that it makes a difference just its funny.
Im trying to decide between 2812's and 3011's, ill most likely being going with 3011's though, i don't think i really need 2812's
Old Nov 23, 2005 | 06:55 AM
MSchu's Avatar
My Name is Nobody
the Swift springs I am buying are metric, why would that seem weird, they also have an ID of 65mm is that wierd? your better off with the 3011's they will stronger for a harsh driving style
Old Nov 23, 2005 | 09:31 AM
CRX Lee's Avatar
I would be interested to know who ran the dyno test and what valving is in the shocks. As mentioned above, it would have been helpful had they better scaled the printout. Also had they chosen some data collection point below .05 m/s or approx. 2 in/s then you would have better seen the low speed damping and the adjustment range.
Old Nov 27, 2005 | 06:28 PM
MSchu's Avatar
My Name is Nobody
Default Re: tell me about this dyno? (CRX Lee)
thanks lee... I do believe Koni ran the tests. Tom fowler put together the set up for me, does that help you out at all?
TyCooley
Nov 15, 2007 07:45 PM
nebulight
Oct 9, 2006 05:42 PM
MarkZeroNine
Aug 23, 2006 12:01 AM
gstintegra92
Feb 7, 2004 07:39 AM
