FS: New fully built h23 block (JE, Saenz, etc.) - 56K warning - buildup pics
-BLOCK IS SOLD-
I am selling my spare H-series blocks...because I have recently built up an F20B and need the money. Everything is in mint condition as seen in the pictures. The motor has never been started or had a head bolted on. The machine work was completed in Nov 2005 and assembly was done last weekend.
The built h23 block includes:
H22 raw block + mains (closed deck h22a1)
JG engine dynamics iron sleeves (piston-to-wall clearance of 0.004") - machine work done at Okanagan Engine
Custom 88.5mm JE forged pistons (9:1, 1.5mm oversize, ringset has been relocated closer to the wrist pin)
JE piston rings - top gap = 0.017-0.018", middle gap = 0.019-0.020"
Saenz I-beam connecting rods with ARP rod bolts (H23 rod length - 3.740")
Balanced & micropolished H23 crankshaft
H22 oil pump gear
Balancing shafts removed
H23 oil pump and crank gear (could also include a h22 crank gear - but no oil pump). H22 tensioner assembly including autotensioner (everything seen in pictures)
Includes all rod and main bearings (that have been plastigauged to spec)
BLOCK IS SOLD
...in addition, I have a stock h22a1 head, intake manifold and throttle body that would work well for those wanting an h23VTEC setup
Modified by XES at 9:38 PM 11/28/2005
H22 oil pump gear
BLOCK IS SOLD
The machine work was completed at the beginning of November 2005, and the assembly was done last weekend (19th of Nov). This is a turbo block and will not make big power without a turbo. On a similar setup on my other motor with a 62-1, I made 550whp and 450ftlbs with an h23 head on C-16 at 22psi. With the addition of a VTEC head, those numbers were made at 15psi. The block should be able to handle anything you can throw at it (at least 700-800whp).
prelittlelude
May 22, 2015 04:49 PM
Boostless97Lude
Jul 22, 2003 09:08 AM
