Component or coax?
I have a set of 4x6 in my doors right now, i'm gonna switch them out for a 6.5" set. I was wondering what the main difference is between component and coax speakers, i was wondering if there is a large SQ difference between the two or if it wouldn't be worth the extra cash for components?
http://www.futureshop.ca/catal...catid=
are they worth 2x the price of coax?
Modified by Spicoli v 3.0 at 11:47 AM 11/21/2005
4x6 speakers in my opinion are absolutly worthless. Cerwin vega made a 4x6 plate back in the day that would fit in a 4x6 spot however it was a plate witha 4'' driver and a seperate tweeter. Those were okay. A component set is addding a seperate x over. With a component set you can aim the tweeters and place them where ever you want. Basicly better sound. Also alot of the x over have circuitry to prevent you from blowing your tweets.
I already have the 4x6 infinity reference series, i wanna upgrade to a round speaker but unsure of the value involved.
THe coax are 150 and the component 300
so are the components in this case worth twice the price? or will i be happy with jsut coax
i'm staying with infinity just wnated some advice from some more experience people.
The biggest diff. I can see between the 2 is power handling the 2way is 60W or 180W peak on the component set there is a misprint it should read 70W or 270W peak, and the component set has a 1.5" tweeter and the coax is a 1" tweeter, the components will have a better and off board x-over, here is something else the think about the MSRP for the REF6010cs is $229.95 http://www.infinitysystems.com/carau...er=REF&Cat=COS
and for the REF6012i it's $119.95 http://www.infinitysystems.com/carau...er=REF&Cat=MEL
Even though that is US $ you may be able to do better.
For the components I would recommend an off board amp. and although the components should sound better, [assuming the install is done properly] the install will be more complicated, [tweeter location and wiring].
As for the components being worth 2x as much, that would entirely be up to you to decide, if you can listen to them, [side by side] do the components sound that much better that you would spend 2x as much.
94
94
Kidnkorner
Southwest (Sales)
Dec 27, 2009 04:24 PM
OKay down to the last three(maybe four) component set with my 200 watt pioneer amp...tell me what yo
eliben95se
Audio / Security / Video
Nov 7, 2004 11:42 AM
