Correct way of checking ATF level
Old Nov 21, 2005 | 06:54 AM
AnAccordIsForever's Avatar
Default Correct way of checking ATF level
The books call for measuring the ATF level when the engine is off, but still hot.
i.e. checking the level within one minute of shutting off the engine.
Most places check the level with engine idling. Which is the correct way ? What are the pros and cons of each ?
Old Nov 21, 2005 | 07:05 AM
Elvis1977's Avatar
Default Re: Correct way of checking ATF level (AnAccordIsForever)
Check with engine off and on level ground. Engine hot or cold, it really does not matter.
Old Nov 21, 2005 | 08:21 AM
cambopheonix56's Avatar
Default Re: Correct way of checking ATF level (Elvis1977)
i believe in park as well.
Old Nov 22, 2005 | 03:55 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AnAccordIsForever &raquo;</TD></TR><TR><TD CLASS="quote">Most places check the level with engine idling.</TD></TR></TABLE>That's the way to check ATF level in most other (non-Honda) cars. Honda is the oddball so a non-specialist garage doesn't always know about that.
Heybeyotch
Feb 25, 2013 11:26 AM
