Falken RT-615 Tire Spec List
Old Nov 21, 2005 | 06:32 AM
EKhothatch's Avatar
Default Falken RT-615 Tire Spec List
Does anyone have or know where I can find the full tire specifications for the RT-615 tire? Falken doesn't seem to have it on their site. I've searched around and found nothing. I have seen it before but I'm not able to find it now. I'm looking for overall tire diameter, etc. for the 205/40R16 tire. Thanks.
Old Nov 21, 2005 | 07:48 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Falken RT-615 Tire Spec List (EKhothatch)
Use a tire calculator like this one.
Some spec sheets are notoriously inaccurate, and others simply calculate the diameter from the tire size the same way the tire calculators do.
Old Nov 21, 2005 | 08:49 AM
EKhothatch's Avatar
Default Re: Falken RT-615 Tire Spec List (nsxtasy)
Thats not going to help. I know what the tire diameter for that size tire is. I would like the tire manufacturers size because some tires are larger/smaller then the default calculated size. I believe these are from what I remember when I saw the original sizes for these.
Does anyone have access to this Spec sheet?
Old Nov 21, 2005 | 10:32 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKhothatch &raquo;</TD></TR><TR><TD CLASS="quote">Thats not going to help. I know what the tire diameter for that size tire is. I would like the tire manufacturers size because some tires are larger/smaller then the default calculated size.</TD></TR></TABLE>
But many manufacturers simply use the dimensions that the tire calculator gives you, rather than calculating it for their specific tire. For example, the specs for the RT-215 (old Azenis) on Falken's website show the outer diameter of the 205/50-15 as 23.1 inches, which is exactly what the tire calculator will give you, whereas this particular tire is notorious for being larger than other tires with the same nominal size. So they aren't giving you the measurements of their actual tire, only what a tire calculator says.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKhothatch &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone have access to this Spec sheet?</TD></TR></TABLE>
It's on Falken's website here (scroll down to the bottom of the page). However, it shows the outer diameter as 23.2 inches, which is more than the spec sheet for the RT-215 in the same size (noted above), whereas the RT-615 is reportedly not as oversized as the RT-215. This is a perfect example of manufacturer spec sheets being "notoriously inaccurate", as I previously mentioned.
Old Nov 22, 2005 | 01:35 PM
EKhothatch's Avatar
Yes, the 215 series are oversized compared to most other tires. I had the 215/45R16 size and love them. I was trying to find out if the 615 series was the same way. I wanted to try the 615 model. I'm running Hankook Z212 (205/45R16) now and like them but I soon need new tires (in the spring). I dont' like the 205/40 size because I dont' want the smaller diameter tire. Thanks for you help with the 2 sites.
Old Nov 23, 2005 | 12:45 AM
@ries's Avatar
22.5 overall tire diameter. scroll down... bottom of the page.
http://www.falkentire.com/615micro.htm
Old Nov 23, 2005 | 07:33 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Falken RT-615 Tire Spec List (@ries)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by @ries &raquo;</TD></TR><TR><TD CLASS="quote">scroll down... bottom of the page.
http://www.falkentire.com/615micro.htm</TD></TR></TABLE>
Gee, I should have posted that.
Oh wait, I already did!
Modified by nsxtasy at 1:03 PM 11/23/2005
Old Nov 23, 2005 | 09:48 AM
@ries's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
well i'll be a monkey's uncle. you're absolutely right. my apologies... easy with the hammers tough guy. lol
Old Nov 23, 2005 | 10:04 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by @ries &raquo;</TD></TR><TR><TD CLASS="quote">easy with the hammers tough guy. lol</TD></TR></TABLE>
xero_xero
Dec 30, 2012 08:08 AM
Rooftop voter
May 21, 2009 05:10 AM
GsDAteg
Nov 30, 2008 04:21 PM
redDAinteg
Apr 20, 2007 05:49 AM
MidwestAutoWorks
Mar 25, 2007 07:05 PM
