all Honda injectors the same?
I got a B18A OBD0 from the junk yard and it had no injectors. I have a set of 90 Si injectors. Can I use them on the B18A? And if so, do I need to get injector grommets for the B18 or the D16? I could see that when I stuck the Si injectors in it didn't fit real snug. But the motor is from a junk yard so maybe the grommets are just worn.
They are the same, I beleive 240cc peak and holds.
Let me edit that, not ALL Honda injectors are the same, just the ones you are looking at are the same
Modified by Autoworks at 3:21 PM 11/21/2005
cool, thanks man. But what about the grommets? Do I need the integra or civic? I'll get the rebuild kit (grommet kit) for the injectors, just need to know witch one. Or I guess if the injectors are the same the grommets would be too?
I'm about 99% sure they are the same, talking about the grommet the goes into the manifold around the injector. I have a bag full of them at home, as far as I remeber they all appear to be the exact same.
