HELP: Is problem my fuel pump?
Old Nov 21, 2005 | 05:20 AM
Dancing is Forbidden's Avatar
Default HELP: Is problem my fuel pump?
So I have this issue that has been going on for a while now. Whenever i am cruising on the highway and am at a steady speed, after about 30 minutes the car acts up. It will bog down really bad and then will sound like the exhaust is brewing coffee (pops and makes a perkolating type sound.) Then it will catch after about 30-45 seconds of this and haul *** (due to the throttle eing pushed down harder to maintain speed. It also seems to burn a lot of gas during this as well.
The only time it gets a cel is when i am decelerating in 5th gear due to the o2 wire being cut. So no CEL during this process at all.
Please help! I am turboing the car this week but am worried as to what this is.
Old Nov 21, 2005 | 07:02 AM
Default Re: HELP: Is problem my fuel pump? (ih8jdm)
noone?
Old Nov 21, 2005 | 07:06 AM
harmonator84's Avatar
well i will say it is not your fuel pump. the honda fuel pump hardly never ever go bad. that would be the last thing. i would check your injectors or something.
Old Nov 21, 2005 | 07:15 AM
EJ2-Fluffy's Avatar
something with ur fuel system.
Old Nov 21, 2005 | 07:20 AM
Default Re: HELP: Is problem my fuel pump? (CRX-Fluffy)
could it be the o2 sensor not being hooked up?
Old Nov 21, 2005 | 07:21 AM
that is a very good possibility
Old Nov 21, 2005 | 08:50 AM
Jesterian's Avatar
24.243.141.75
Default Re: HELP: Is problem my fuel pump? (harmonator84)
No input, but I voted for not ruining the poll
Old Nov 21, 2005 | 08:55 AM
Suck my DX's Avatar
Default Re: HELP: Is problem my fuel pump? (Jesterian)
when was the last time u changed ur fuel filter?
Old Nov 21, 2005 | 09:27 AM
Default Re: HELP: Is problem my fuel pump? (Suck my DX)
about 1200 miles ago.
Old Nov 21, 2005 | 09:45 AM
Suck my DX's Avatar
i c...i would still check it to see if it got gunked up or not....sometimes people fill up their gas at the pump when those big truckers are filling the gas stations tanks...just think all that gas is going into their tank so its gonna make all the gunk on the bottom get stirred up...u never know...it could also be gunk in ur fuel lines..u should hope not cuz that is a bitch to flush out...i wouldnt go turbo till u get this sorted out....does the motor temp go up when this is happening
Old Nov 21, 2005 | 10:13 AM
CPT.PANDA's Avatar
my car is doing the samething.
Old Nov 21, 2005 | 05:10 PM
mahatma's Avatar
Default Re: (jedi_139)
Mine had those very symptoms with bad oxygen sensor. The sputtering at steady speeds and CEL on deceleration.....
O2 fixed it......
Old Nov 21, 2005 | 08:00 PM
sidewayz32's Avatar
sorry i don't know what your problem is, but you should definately hold off on turboing it until you get this problem sorted out. you're just asking for trouble otherwise.
91blackEF
Apr 5, 2021 03:23 PM
justbriaN
12
Mar 2, 2011 02:25 PM
BAnnedx3
Jun 18, 2007 12:24 PM
ninetyfourgsr
Jul 3, 2002 11:21 PM
