vafc or chipped ecu?
Well, assuming the only mods you got done is whats in your description in your signature.... (i/h/e), I'd stick with the stock ecu.... and if you have the extra funds, then get a vafc to fine tune.
sorry i need to update that thing
GSR BLOCK
-ctr pistons
-blanced crank
GSR HEAD
-omnif flat stock sized valves
-blox hsl cams
-blox springs
-blox titanium retainers
-skunk 2 proseries intake
-skunk 2 cam gears
-fuel rail
-fuel pressure regulator
MISC
apex n1 exhaust
dc header
cheap intake
motor mount inserts
8lbs fidanza flywheel
exedy racing clutch
GSR BLOCK
-ctr pistons
-blanced crank
GSR HEAD
-blox hsl cams
-blox springs
-skunk 2 cam gears
-fuel rail
MISC
apex n1 exhaust
dc header
cheap intake
motor mount inserts
exedy racing clutch
