Suspension & Brakes Theory, alignment, spring rates....
GSR Steering Rack in EG Civic - Question
Old Nov 20, 2005 | 09:47 PM
cord4530's Avatar
Default GSR Steering Rack in EG Civic - Question
Hey all,
I'm in the middle of swapping in a GSR steering rack in to my 93 civic si and ran in to a small snag. The input shaft for the GSR rack is a different size than the input shaft from the original civic power steering rack. Has anyone run in to this before? Can the u-joint connector from the integra be used to fix this? Or is there a different solution I'm not aware of?
Any tips would be appreciated. The car is not useable currently, so I'd like to find the part/solution asap. Thanks in advance--
Dan Cordon
cord4530@uidaho.edu
Old Nov 21, 2005 | 07:43 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: GSR Steering Rack in EG Civic - Question (cord4530)
You could try taking your Civic U-Joint to the autoparts store & comparing it with an integra one. If you carefully count the splines, you would know if it's what you need...
And if it's not, it didn't cost you a thing...
Old Nov 21, 2005 | 08:29 AM
Kendall's Avatar
The U-joint from an Integra will work perfectly.
Old Nov 21, 2005 | 08:33 PM
cord4530's Avatar
Default Re: (Kendall)
Thanks for the tip! I was hoping it would be that simple. Just to confirm.....when you swapped in an integra rack, the input shaft was too large for your civic U-joint shaft, and one from a (94-01???) Integra was the correct one?
That's great news!
Dan Cordon
SpeedRacerEX-R
Suspension & Brakes
Jun 6, 2016 03:39 PM
tranza
Feb 21, 2013 05:00 AM
AMGkobez
May 10, 2009 05:10 PM
drift2004
Suspension & Brakes
Oct 6, 2008 09:15 PM
