stock spring rates si,dx,hf
Old Nov 20, 2005 | 07:03 PM
coot_er's Avatar
Default stock spring rates si,dx,hf
i was wondering if anyone knew the stock spring rates for all three models or the rex. thanks
Old Nov 20, 2005 | 07:37 PM
Crimson_Tide's Avatar
Default Re: stock spring rates si,dx,hf (coot_er)
i think the spring rates are like 10... or at least thats what it looks like when watching you autox ... lol just messin man... bump for an answer
-Josh
Old Nov 20, 2005 | 08:48 PM
Tyson's Avatar
stock Si spring rates are on the order of 250/100-150.
i dont know the difference that the HF is.
Old Nov 21, 2005 | 01:03 AM
Zero2SixtySound's Avatar
Here is an incomplete spring rate table, it might help...
http://php.indiana.edu/~bchang....html
Ben, has a lot of good information about EF's, I would check his TECH section on EF hybrid suspension, it tells you all you need to know about swapping suspension parts on EF's.
http://www.ef-honda.com/ben/
good luck,
Steve
Old Nov 21, 2005 | 08:13 AM
Dancing is Forbidden's Avatar
Default Re: stock spring rates si,dx,hf (Zero2SixtySound)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">stock Si spring rates are on the order of 250/100-150.
i dont know the difference that the HF is.</TD></TR></TABLE>DAMN! YAY! I run 800r and 650f and LOVE IT
Old Nov 21, 2005 | 08:34 AM
Jesterian's Avatar
24.243.141.75
Default Re: stock spring rates si,dx,hf (Tyson)
Is there a difference? I was thinking about replacing my stock springs and putting on some koni yellows, but if Si springs are a little stiffer, I might go with those.
Old Nov 21, 2005 | 08:37 AM
Tyson's Avatar
Default Re: stock spring rates si,dx,hf (Jesterian)
i just checked the part numbers, they show up as the same part number. so i suppose not. the difference is just in the swaybars i guess.
interestingly, the 3dr civics have different part numbers. hmm....
wernhersey
Suspension & Brakes
Jun 30, 2009 01:12 PM
user 9782082308
Jan 16, 2003 07:25 AM
