Car shakes at idle and start up. Engine light is on.
Old Nov 20, 2005 | 06:55 PM
awwsnap's Avatar
Default Car shakes at start up and in idle. Engine light is on.
hey guys i have a 96 honda civic ex coupe and recently a lot of times when i start my car its been shaking really bad, even at idle! (also, the engine light just turned on about the same time this started happening.) when driving, it continues to shake when i'm going in the low 20s but once i get above 25 mph, (it's an automatic, but i think once it gets to a particular gear) the shaking goes away. i figured that it was just the spark plugs, cap, and rotor so i replaced all those today but i'm still having the same problem. with the engine light i think it might be the O2 sensor, but with the shaking i have no idea whatsoever. please help!!!
Old Nov 20, 2005 | 07:07 PM
deadlock32's Avatar
Default Re: Car shakes at start up and in idle. Engine light is on. (awwsnap)
fuel injector? turn the car on. pull out spark boot 1... shakes worse? put back in, take out spark boot 2, shakes worse? put back in. continue. When you find that one of the spark boots you take out doesnt affect the shaking (it stays the same) the problem is in that cylinder. (if a particular cylinder has a problem)
Old Nov 21, 2005 | 08:26 PM
awwsnap's Avatar
Default Re: Car shakes at start up and in idle. Engine light is on. (deadlock32)
Would this be the only possibility?
Old Nov 21, 2005 | 08:43 PM
kyden's Avatar
heres a thought... find out the code is for..
Old Nov 21, 2005 | 09:49 PM
gray_civic_coupe's Avatar
my car shakes as well when i start it and the rpm jumps between 2000-2200 rpm maybe
and when the engine's tepm reachs half the shaking stops but the rpm is still high around 2000 rpm..
and if I switch off the car and then start it again the rpm falls to 1200 rpm maybe and when i start driving the car and then stop on the trafic or so you can see it @ 2000 rpm
I dunno why! I pulled out the spark boots one by one and the shaking got worse, so that means there is nothing wrong in the cylinders.
did anybody face such a problem before?!
Old Nov 22, 2005 | 04:46 AM
Crank's Avatar
Default Re: (gray_civic_coupe)
IACV
Old Nov 22, 2005 | 11:06 AM
Default Re: (Crank)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crank &raquo;</TD></TR><TR><TD CLASS="quote">IACV </TD></TR></TABLE>
what is this ?
Old Nov 23, 2005 | 09:28 PM
bump
Old Nov 23, 2005 | 09:30 PM
ROK801's Avatar
is the car revving at idle?
does the car want to die at idle?
Old Nov 23, 2005 | 09:32 PM
ROK801's Avatar
Default Re: (ROK801)
IACV = IDLE AIR CONTROL VALVE
Old Nov 23, 2005 | 09:54 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ROK801 &raquo;</TD></TR><TR><TD CLASS="quote">is the car revving at idle?</TD></TR></TABLE>
yes
Old Nov 23, 2005 | 09:59 PM
ROK801's Avatar
idle air control valve...
theyre a few bucks at autozone...
easy to install too.
someone at autozone should even be able to help you if you dont know how.
Old Nov 23, 2005 | 10:34 PM
civic_driver's Avatar
get the code... then get back to us if you can't figure it out.... autozone can do a free code scan if you don't know how to read the cel blinks
madcat501
Honda Civic (2006 - 2015)
Jun 29, 2010 05:43 PM
949
Oct 14, 2009 05:19 PM
EPerez88
Nov 12, 2008 10:01 PM
Downz
Apr 24, 2006 11:55 AM
redlines4us
Nov 18, 2005 07:37 PM
